Lpc 1343 Sram
Hi I am working in project that need 64 kbyte sram. Can I connect Lpc1343 to external Ram?
  • Yes, you can. But I don't think it will work as you think it should.
    If you need lots of memory, you should select a processor that either have lots of memory or a dedicated memory expansion bus. The LPC13xx series intended each and every pin to be GPIO, power, ground, oscillator, ... or mapped to one of the internal peripherial devices.
    The LPC13xx chips are small, simple, chips where price is important and functionality requirements are limited. They are not designed with a Swiss army knife of extension interfaces to make it into a LPC17xx when you need more capabilities - the designer is expected to directly select a LPC17xx if that is what is needed for the task.
  • Well it doesn't claim to have an external bus, now does it?
    www.nxp.com/.../LPC1311_13_42_43.pdf
    You might be able to interface one using all the available IO, but I'm not sure that's practical, and your project probably has other requirements for those.
    Perhaps you can find a CPU better suited to your needs, external memory tends to be bandwidth limiting.
    Reading technical documentation is a very important engineering skill.
  • OK Thanks for help I connect ov7670 to mcu size of each frame is 20 kbyte.
