.\Targets\STM32F429_Discovery\project.axf: error: L6047U: The size of this image (62716 bytes) exceeds the maximum allowed for this version of the linker
Hi to everyone!How can i solve this error? I have the MDK-Lite Evaluation Mode which you cant write above the 32K of the size of the code.what can i do to write adove the 32K of the size of the code??
Go on - you've got a product with specific limitations; if you want to exceed those limitations, then you are clearly going to have to get a different product (or different version of the product) without those limitations.
Keil have various product options available - look at the 'Products' section of the website (the clue is in the name).
Other vendors are available ...
If you are doing large, empty, static allocations, consider increasing the heap and doing dynamic allocations.
If the code/data is still too large you'll need to consider purchasing a license.
thank you very much!
