Are KEIL tool chains compatible with arm-none-eabi-gcc
Does KEIL use the open source tool chain such as arm-none-eabi-gcc or does it use its own custom toolchain?
The reason I ask is we develop our libraries for the STM32F0 device but our libraries have to work with a different environment which uses open source arm-none-eabi-gcc.
So when I compile our libraries in KEIL, will it be compatible with an Eclipse based that uses arm-none-eabi-gcc? Can the .lib file from KEIL be understood by the arm-none-eabi-gcc toolchains?
Thanks.
0
