Hi, I am using a stm32f4 discovery board to control a servo motor (Servo 6009). But, I have some problems, please help me to solve these.
- when I write " Rotation_Servo(void)", it run correctly. void Rotation_Servo(void); int main(void) { TIM_PWM_Configuration(); while(1) { Rotation_Servo(); } } void Rotation_Servo(void) { int b=150; int a=(b + 65.5) / 0.1; TIM1->CCR1 = (uint32_t)a; Delay(60000000); } - but when I replace: "Rotation_Servo(void)" by "void Rotation_Servo(int b)" like bellow, It can not run. void Rotation_Servo(int b); int main(void) { TIM_PWM_Configuration(); while(1) { Rotation_Servo(150); } } void Rotation_Servo(int b) { int a=(b + 65.5) / 0.1; TIM1->CCR1 = (uint32_t)a; Delay(60000000); }
Please try to read the posting instructions for source. http://www.keil.com/forum/tips.asp
I would start by doing the math in float and then convert to a uint16_t, mixing float/int math without casting is prone to misinterpretation, especially when the compiler is folding the math
