some errors
hi. when I compile the can sample code(LPC1768 board) below errors are appeared. can you tell me what is the problem and what can I do?
F:\project\libraries\Serial.c(21): error: #5: cannot open source input file "Serial.h": No such file or directory
F:\project\libraries\RTX_CAN.c(32): error: #60: this operator is not allowed in an integral constant expression
C:\Keil\ARM\RV31\Inc\RTX_CAN.h(13): error: #5: cannot open source input file "CAN_Cfg.h": No such file or directory
  • You don't actually have a number of files, or they are not situated on the Include Paths where the compiler might find them?
    What do you think "No such file or directory" means?
    Double check if these files exist in your project directory, or other examples, or if you're expected to provide them as settings specific to your board/chip?
  • your right. but I made a new folder and put my main project and all of it's related files in that. so I think these files are exist in my project directory. I think there is another problem :( I have been read before in another site, that I should set the correct path from target options/ c,c++ / include paths (in keil). but I don't remember what was the correct path. can you help me plz?? :)
