I have a problem by using Keil.The error message is here:*** FATAL ERROR L214: INPUT PHASE ERROR I have seen uVision help , but i still can not understand this error. Does anyone konw it? Thanks for helping me.
When I change BL51 to LX51, there is no error.But the program can not run normally.
Phase errors typically occur when things change between passes in the linker/compiler/assembler.
ie where ordering of things is changed, values change, or that moving one function, or calling method, changes another and the knock on effect is a meta-stability between passes. Look carefully at what compiler/linker directives/options/optimizations you have chosen.
http://www.keil.com/support/docs/1066.htm Contact technical support, this is not technical support
Thank you very much.Now i know what i should do.Thanks again.
Surprised to see the same question here...
