Hi All,
It appears to me that the config wizard for the 'out-of-the-box' K10 start-up file does not work. I'm particularly interested in settings for the FOPT (Start-up options) byte.
Here's a fragment of the code from startup_MK10DN10.s :
; </h> ; <h> Flash nonvolatile option byte (FOPT) ; Allows the user to customize the operation of the MCU at boot time. ; <o.0> LPBOOT ; <0=> Low-power boot ; <1=> normal boot ; <o.1> EZPORT_DIS ; <0=> EzPort operation is enabled ; <1=> EzPort operation is disabled FOPT EQU 0xFF
So the default FOPT is 0xFF yet the wizard says "Low-power boot" and "EzPort operation is enabled" which would be 0xFE.
It gets worse.... If I use the wizard to change FOPT so that Low-power boot is disabled and EzPort is also disabled the source code changes to:
; </h> ; <h> Flash nonvolatile option byte (FOPT) ; Allows the user to customize the operation of the MCU at boot time. ; <o.0> LPBOOT ; <1=> Low-power boot ; <1=> normal boot ; <o.1> EZPORT_DIS ; <2=> EzPort operation is enabled ; <1=> EzPort operation is disabled FOPT EQU 0xFF
Note that what's been changed is part of the wizard script NOT the FOPT byte. I suspect that some of the other wizard settings in this file are wrong too. BTW there's no mention of NMI Disable which is bit 2 of FOPT.
I'm using uVision 5.15 and Kinetis pack for K10 1.1.0
Regards, Martin (UK).
