Hi to you all thank you for all the suggestions in relation to this problem. I am posting the linker file for you to examine.I also have talked to the programmer that had previously been working for the company and he tried also to overcome the problem but with no luck.
clock.obj, codes.obj, com_test.obj, comms.obj, config.obj, control.obj, crc.obj, & eng_cod.obj, hols.obj, ind_init.obj, & initmod.obj, inputs.obj, int10ms.obj, intercom.obj, keybd.obj, keyin.obj, & lcd_mod.obj, man_cod.obj, mode_mod.obj, outputs.obj, overide.obj, & print_c.obj, print_m.obj, print_r.obj, print_s.obj, printer.obj, & records.obj, sensors.obj, settime.obj, setup.obj, site_cod.obj, start.obj, & strings.obj, test.obj, utils.obj, zone.obj , startup.obj, disp_int.obj, & ramdata.obj, e2_data.obj, s_zone.obj, s_sensor.obj, s_output.obj, & s_input.obj, s_lux.obj, s_w_snsr.obj, s_codes.obj, r_sensor.obj, & r_zone.obj, r_output.obj, r_input.obj, clockdat.obj, time.obj, display.obj, datatran.obj & TO V10001e.abs & RAMSIZE(256) CODE(0100H) XDATA(?xd?r_zone(00000H), ?xd?r_sensor(000e0H), & ?xd?r_output(00240H), ?xd?r_input(002e0H), ?xd?ramdata(00310H), ?xd?s_codes(0d007H), & ?xd?s_zone(0d037H), ?xd?s_sensor(0da1fH),?xd?s_input(0db67H), & ?xd?s_output(0dd87H), ?xd?s_w_snsr(0deffH), ?xd?s_lux(0df01H), & ?xd?clockdat(0E010H),00000H) & SYMBOLS PUBLICS
Also here is the exact error message
Linking *** FATAL ERROR 204: INVALID KEYWORD C:\C51\BIN\BL51.EXE C:\V10001E\C\CLOCK.OBJ,C:\V10001E\C\CLOCKDAT.OBJ, C:\V10001E\C\CODES.OBJ,C:\V10001E\C\COM_TEST.OBJ,C:\V10001E\C\COMMS.OBJ, C:\V10001E\C\CONFIG.OBJ,C:\V10001E\C\CONTROL.OBJ,C:\V10001E\C\CRC.OBJ, C:\V10001E\C\DATATRAN.OBJ,C:\V
Maybe your command line is too long. Take a look at the section on command lines/files in the manual. Please don't keep starting new threads unless you are talking about a different problem. What is this "# symbol" you keep going on about? Stefan
The # symbol appeared previously with the error report without it being part of the linker control file. Well I will truncate it somewhat and see what happens. I didnt realise you cannot start a new thread about an ongoing problem. Any way thanks for that.
Well, I've just managed to force an L204 error with BL51 v5.03, and it looks like this:
*** FATAL ERROR L204: INVALID KEYWORD POS: 772 51_lst\Ml_test.map) PAGEWIDTH (132) PAGELENGTH (32760) PRINTCONTROLS (#
Can you post the error message as it appears at the bottom of the MAP file? Jon
I have posted the error message exactly as it is reported also I tried to open the .LER with the textpad editor but icame with some weird characters as you see the compiler is not reporting the position of the error all I get is what I have written
"I didnt realise you cannot start a new thread about an ongoing problem." The whole idea behind a thread is that you can see the entire discussion in one place. If I want to see what you've said before and what advice you have been given I can just scroll up and down rather than having to go and locate the other threads that contain bits of the discussion. It just makes sense...
I am using a command file called link.ctl not the command except of I am mixing things up and reporting the error properly I have put verbatim error message.In the Code banking linker setup on the command line link options I have the line @C:\V10001E\LINK.CTL I think I will truncate the file and see what happens
Sorry but I havent been on a discussion forum before so I am not sure how they work what you call the MAP? Is that the linker file renamed?
Jon
That is not the error. Can you post the error message as it appears at the bottom of the MAP file? Also, can you post the command line as it appears in the MAP file? Jon
Is the map file the file with extesion M51?
yes
Jon Here is the map file
BL51 BANKED LINKER/LOCATER V4.02 09/29/2003 16:27:05 PAGE 1 BL51 BANKED LINKER/LOCATER V4.02, INVOKED BY: C:\KEIL\C51\BIN\BL51.EXE C:\V10001E\C\CLOCK >> .OBJ, C:\V10001E\C\CLOCKDAT.OBJ, C:\V10001E\C\CODES.OBJ, C:\V10001E\C\COM_T >> EST.OBJ, C:\V10001E\C\COMMS.OBJ, C:\V10001E\C\CONFIG.OBJ, C:\V10001E\C\CONT >> ROL.OBJ, C:\V10001E\C\CRC.OBJ, C:\V10001E\C\DATATRAN.OBJ, C:\V10001E\C\DISP >> LAY.OBJ, C:\V10001E\C\E2_DATA.OBJ, C:\V10001E\C\ENG_COD.OBJ, C:\V10001E\C\H >> OLS.OBJ, C:\V10001E\C\IND_INIT.OBJ, C:\V10001E\C\INITMOD.OBJ, C:\V10001E\C\ >> INPUTS.OBJ, C:\V10001E\C\INT10MS.OBJ, C:\V10001E\C\INTERCOM.OBJ, C:\V10001E >> \C\KEYBD.OBJ, C:\V10001E\C\KEYIN.OBJ, C:\V10001E\C\LCD_DAT.OBJ, C:\V10001E\ >> C\LCD_MOD.OBJ, C:\V10001E\C\MAN_COD.OBJ, C:\V10001E\C\MODE_MOD.OBJ, C:\V100 >> 01E\C\OUTPUTS.OBJ, C:\V10001E\C\OVERIDE.OBJ, C:\V10001E\C\PRINT_C.OBJ, C:\V >> 10001E\C\PRINT_M.OBJ, C:\V10001E\C\PRINT_R.OBJ, C:\V10001E\C\PRINT_S.OBJ, C >> :\V10001E\C\PRINTER.OBJ, C:\V10001E\C\R_INPUT.OBJ, C:\V10001E\C\R_OUTPUT.OB >> J, C:\V10001E\C\R_SENSOR.OBJ, C:\V10001E\C\R_ZONE.OBJ, C:\V10001E\C\RAMDATA >> .OBJ, C:\V10001E\C\RECORDS.OBJ, C:\V10001E\C\S_CODES.OBJ, C:\V10001E\C\S_LU >> X.OBJ, C:\V10001E\C\S_OUTPUT.OBJ, C:\V10001E\C\S_SENSOR.OBJ, C:\V10001E\C\S >> _W_SNSR.OBJ, C:\V10001E\C\S_ZONE.OBJ, C:\V10001E\C\SENSORS.OBJ, C:\V10001E\ >> C\SETTIME.OBJ, C:\V10001E\C\SETUP.OBJ, C:\V10001E\C\SITE_COD.OBJ, C:\V10001 >> E\C\START.OBJ, C:\V10001E\C\STRINGS.OBJ, C:\V10001E\C\TEST.OBJ, C:\V10001E\ >> C\UTILS.OBJ, C:\V10001E\C\ZONE.OBJ, C:\V10001E\C\TIME.OBJ TO C:\V10001E\V10 >> 001 RS (128) PL (68) PW (78) *** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: C:\V10001E\.OBJ
Jon thanks for all your help sorry for my level of ignorance on the Keil.I have just realised I have done a mess of a lot of things as I have renamed one project file yet I think all the associated are linking the ols project. I have never actually have had set up a compiler where I worked with the motorola all of that was done by senior engineers. I just wrote C all day sorry If I have p$$$ed you off never meant to.
