Hi to you all thank you for all the suggestions in relation to this problem. I am posting the linker file for you to examine.I also have talked to the programmer that had previously been working for the company and he tried also to overcome the problem but with no luck.
clock.obj, codes.obj, com_test.obj, comms.obj, config.obj, control.obj, crc.obj, & eng_cod.obj, hols.obj, ind_init.obj, & initmod.obj, inputs.obj, int10ms.obj, intercom.obj, keybd.obj, keyin.obj, & lcd_mod.obj, man_cod.obj, mode_mod.obj, outputs.obj, overide.obj, & print_c.obj, print_m.obj, print_r.obj, print_s.obj, printer.obj, & records.obj, sensors.obj, settime.obj, setup.obj, site_cod.obj, start.obj, & strings.obj, test.obj, utils.obj, zone.obj , startup.obj, disp_int.obj, & ramdata.obj, e2_data.obj, s_zone.obj, s_sensor.obj, s_output.obj, & s_input.obj, s_lux.obj, s_w_snsr.obj, s_codes.obj, r_sensor.obj, & r_zone.obj, r_output.obj, r_input.obj, clockdat.obj, time.obj, display.obj, datatran.obj & TO V10001e.abs & RAMSIZE(256) CODE(0100H) XDATA(?xd?r_zone(00000H), ?xd?r_sensor(000e0H), & ?xd?r_output(00240H), ?xd?r_input(002e0H), ?xd?ramdata(00310H), ?xd?s_codes(0d007H), & ?xd?s_zone(0d037H), ?xd?s_sensor(0da1fH),?xd?s_input(0db67H), & ?xd?s_output(0dd87H), ?xd?s_w_snsr(0deffH), ?xd?s_lux(0df01H), & ?xd?clockdat(0E010H),00000H) & SYMBOLS PUBLICS
I have in this project link.ctl but no .lin file what is the difference between these 2? I posted what I thought was the linker file but now I think I may have been wrong all along. Here are the files and folders as listed in widows explorer with their extensions from the original file I have been working from. Top folder is V10001e inside this I have C folder h folder d ms-dos batch file link.bak link.ctl o.bat v10001.ABS v10001.LER V10001.prj V10001e.abs V10001e.hex v10001e.M51 why some file end with e and why some don't I am not sure. Is there a linker file here??
It looks like your linker command file is corrupt. You mentioned before something about funny characters - that would certainly mess things up!
You are clearly very confused. I suggest you create a new project directory, then work through the "Getting Started" manual and create an entirely new project from scratch. This should give you a better understanding of what is going on. Stefan
I didnt realise you cannot start a new thread about an ongoing problem. There's no rule that says you can't. But, it does make it a lot harder for anyone to get a complete picture of what's exactly going on. Jon
Did both of these listings come from the same map file? Jon
This doesn't match your previous error of:
Linking *** FATAL ERROR 204: INVALID KEYWORD
As Stefan says, you seem to be very confused by all this; and it doesn't sound like you have anyone else to hand who really knows the tools to assist you? If you're in Southern England, maybe we could help you out with a day's on-site Consultancy - look at this problem and give you a general walk-though on the Tools? If you're interested, mail
Sales at Antronics dot co dot uk
I finally solved the problem as I reverted back to the original version of software but using a dongle of another version as the original dongle along with the original software cannot be found at the moment. So all the problems disappeared once I got the version back using the original installed directory copied over the C51 and Keil directories so I have a working enviroment of sorts. As you said I have little experience with the Keil tools and as you guessed I am working completely on my own with no one to assist me but at the moment I don't see any likelyhood of the company paying for seminars. So anyway I will persevere for the moment. Still in the case Im in up to my eyeballs with problems I will have to seek external consultancy.
"I don't see any likelyhood of the company paying for seminars." Your 1st post on this subject was 24 Sep; you apparently got someting working on 7 Oct. For the benefit of the bean-counters, you might like to tot-up the cost of those 10 lost working days (I assume you didn't work weekends?) against a day's training/consultancy. Not forgetting, of course, to use your company's full overhead rate - probably at least 2x your hourly rate... :-0
