STM32F4 Discovery Trace: No Synchronisation
I set up a project with CUBEMX and Keil RTX like it is described here www.keil.com/.../cubemx__r_t_x.html
Setup the SysClk with CUBEMX to 168Mhz and enabled serial wire debug in the SYS tab.
1drv.ms/.../s!AtZm9jQhSOu4imdxPVTflXC9s-nX
And the Debug/Trace like this
1drv.ms/.../s!AtZm9jQhSOu4imi4eZI4WSCIAwXv
I wrote a sipmle programm and compiled it and it is running but i cannot use the event viewer and there is no ITM stimulus.
1drv.ms/.../s!AtZm9jQhSOu4imlS7J8Ws7io4Xjh
If you need more info just ask. I've been searching sor a soulution for 2 days now.
0
