Spurious warning C180
I just upgraded to uVision 5.21.1.0 and Compiler V7.56.0.0
This sample code produces warning C180: 'myFunc': not every path returns a value. The warning was not produced by the previous version of uVision/Compiler that I was using.
void dummyFunc(void)
int
myFunc(void)
  int a;
  for ( ;; ) {
    if ( a==0 )
      return a;
    dummyFunc();
If I comment out the call to dummyFunc() then the warning does not occur.
If I comment out the if and return statement lines then the warning does not occur.
Anyone know why the code "as-is" produces the warning? As far as I can see the function does return a value for all return paths - which is just one: "return a".
Paul
0
