Hi there Keil forums, I have a question about how my LPC 1114 responds to data over a Uart connection.
This is my UART interrupt code:
/* UART Data Received Interrupt */ void UART_IRQHandler(void) { static NetworkLayerState networkState = Network_Idle; unsigned int interruptId = LPC_UART->IIR; while((interruptId & 1) == 0) { switch((interruptId >> 1) & 0x07) { case 0x02: //Receive Data Available case 0x06: //Character time-out indicator (buffer flush) networkState = NetworkStateMachine(LPC_UART->RBR & 0xFF, networkState); break; case 0x03: //Receive Line Status interrupt break; //Not handling frame errors } interruptId = LPC_UART->IIR; } }
My computer and mcu are connected via a usb to uart cable. I want to know what kind of data I need to send to my mcu in order to trigger this interrupt. For example if I want to send the integer "1" to my mcu how would I do that and then I can store that integer value in a variable within the firmware of the MCU. My GUI is done in C# and it is what I use to communicate with the mcu.
Basically identically the same question Anthony Serra asked: http://www.keil.com/forum/59814/
You want a serial port to receive "1"?
Don't you then think the most logical thing to send would be "1"? The UART doesn't do anything magic. You send three characters '1', '2', '3' to it and it will receive '1', '2', '3' assuming the data was sent with the correct baudrate, number of data bits etc.
And as already discussed earlier - you can use a terminal program instead of that GUI and just send any characters you like. The UART will then receive exactly the same characters.
A microcontroller's UART (and a PC's COM port) just sends and receives bytes - it neither knows nor cares anything of the meaning or interpretation of those bytes.
When a microcontroller's UART (and a PC's COM port) sends a byte, it neither knows nor cares anything of the destination of that byte. It just sends; the destination is irrelevant.
When a microcontroller's UART (and a PC's COM port) receives a byte, it neither knows nor cares anything of the source of that byte. It just receives; the source is irrelevant.
So it's entirely up to you how you want to represent your data over the link.
Sending a "1" is a trivial case - you can either send a single byte with the numerical value one (0x01), or you can send a single character '1'.
Things get more interesting when you need to send stuff that can't be represented in a single byte, but you still have basically the same choice: either send as a "raw" numerical value, or send as a text string (a sequence of characters).
To send characters, you would encode them using ASCII
en.wikipedia.org/.../ASCII
http://www.asciitable.com/
There is a proviso there:
Some communication links may interpret certain byte values as "special" and use them as "control codes".
In particular:
* So-called "software" flow control uses the X-ON and X-OFF codes to start & stop transmission: en.wikipedia.org/.../Software_flow_control
* Some systems may translate "end-of-line" sequences; eg, expanding CR to CR+LF: en.wikipedia.org/.../Newline
This will obviously interfere with you sending your stuff as "raw" numeric values...
en.wikipedia.org/.../transmitter
And, of course, be sure to study the UART section in your chip's Datasheet (or "user manual" or whatever the manufacturer calls it).
