can the keil 5 run to windows 8?, because I have installed keil 5 to windows 8.1 but there are several problem, likes "user code template" in add new item to group "source group 1" can't be open.
thanks
Hello Abdul, yes - Windows 8 is supported with MDK-ARM V5.xx - please refer to: www2.keil.com/.../
Regarding the "User Code Template" issue - make sure that you have installed the matching Software Pack - for more details refer to: http://www.keil.com/support/man/docs/uv4/uv4_ca_sourcefiles.htm http://www.keil.com/pack/doc/CMSIS/Pack/html/index.html www.keil.com/.../_c_p__s_w_components.html
If your problem persists please forward your project to our Support Team: support.intl@keil.com
Kind regards, Ralf
R.Kopsch Senior Applications Engineer ARM Germany GmbH
thanks for your attention and your cooperation,
I have tried and followed your instruction, but 'user code template' consistently can't be open. do I have reinstall my keil program and than install it again? or how do I?
as a notice: 1. I am a new user ARM microcontroller and this is the first time to use keil program 2. I want to use nuvoton NUC120RD2BN to control motors speed and to communicate with others device, likes: LCD, keypad, RTK DGPS
Thanks for your attention best regard,
Abdul Asiz
Hello, no, a new installation is not solving such an issue, but I'd like you to detail "but 'user code template' consistently can't be open", unless a) does not help:
a) the "Nuvoton NUC120RD2BN" is supported with MDK-5: http://www.keil.com/dd2/nuvoton/nuc120rd2bn/ That link also offers the access to the Software Packs.
b) As being a beginner I'd like to recommend to you some links:
- Intro and “Getting Started” – Guide: http://www2.keil.com/mdk5/
- “Learning Platform for Cortex-M Microcontroller Users”: www2.keil.com/.../learn
- Keil On-line User's Guides and Manuals http://www.keil.com/support/man/
- Distributor List: http://www.keil.com/distis/
- Keep in mind that we also offer out support at: support.intl@keil.com
Best regards, Ralf
