After donwload and build with success the Project MEMS from APNT_271 (from here www2.keil.com/.../)
I´m receiving an error "No ULINK Device found", when I try to LOAD the Fash, Freescale FRDM-K64F.
Any help about my configuration for the project? What am I missing?
Many thanks in advance!
Waldemir.
And do you have any ULINK device?
Clearly, if you don't have one - uVivion won't be able to find it!
Thanks Andrew for your answer,
That´s the reason of my question :) I don´t have it and I didn´t find a way to configure my uVision5 to no go to this error. So my question is how I can work around this.
Any link or direction where I can find more Information how to configure my Project or Utilities tab in the uVision5?
Many thanks!
Wouldn't you go to the Project Options -> Debug, and pick something like CMSIS-DAP instead of the U-LINK you don't have?
Similar for the Utilities, to either "Use Debug Driver", or the CMSIS-DAP
www.freescale.com/.../prod_summary.jsp
"CMSIS-DAP debug interface over a driver-less USB HID connection providing run-control debugging and compatibility with IDE tools"
Take a look to the PDF file http://www.keil.com/appnotes/files/apnt_271.pdf The appnote uses a JLINK debug unit (page 2) and you should select the JLINK debug adapter also under Options for Target - Debug (http://www.keil.com/support/man/docs/uv4/uv4_debugging.htm).
