ARM KEIL uVision v4.50.0.0 support for Infineon USB Wiggler (XC164CM-8F40F)
Whilst using ARM KEIL uVision v4.50.0.0 for a project targeting XC164CM-8F40F with a USB Wiggler connected to the Microcontroller over a OCDS port it was noted that under the Flash Menu both the Download and Erase options were greyed out.
Next the "Configure Flash Tools" option was selected on the Flash menu. With the radio button selected (by default) on "Use Target Driver for Flash Programming" the drop down list box immediately below does not contain the USB Wiggler as an option.
Please can you anyone advise.
