MDK-ARM compilation of huge data
Hi all,
There is a need for compilation of structure that contains more than 7 MB of data. MDK-ARM (Professional, version 5.12.0.0) stops working after compilation, though a binary file is successfully created. As one can understand from Keil site there is a limitation: an output file nor grater than 4 megabytes can be generated. It was practically checked that in case when data did not exceed 4 megabytes, compilation finished successfully with no failure of Keil's work but adding data over 4 MB leads to failure. However, it must exist some ways to bypass this restriction. Could someone tell how to compile such huge data, please?
Thanks in advance!
  • If the 7MB is code then you need to accept the limitation of the tools.
    If a number of MB is a "database" of const data, then you can generate that data separately and load to an absolute address and have your application access the data with a pointer or similar. There is no need to have the compilation also include font data, images etc - it would be trivial to write a PC program that compiles this resource information and produces a table with the offset of the different resources.
  • Did you consider to split the data into two modules?
  • One important question:
    Is there some limitation on code generation? We have a system with two 128 MByte Flash + one 64 MByte Flash. So if so we have to change the development tools very fast.
  • There should be no issue with that sizes. The linker of the ARMCC is in use since many many years, for example to generate the images of mobile phones. These are much bigger than what you describe.
    What we would like to understand is the problem that has been described by Tetyana, but it looks like he does not reply.
  • Many thanks for the quick clarification.
  • I in the same situation as in Tetyana, and I think you're right, the problem is not in the compiler. I use the comand D:\Keil\ARM\ARMCC\bin\fromelf.exe --bincombined --bincombined_base=0x00000 --bin Objects\XXXX_ST.axf --output Objects\XXXX_STbin, to generate a binary file with font, string and icons, if my otput file is less than 7 MB Keil work perfectly, But if I add all the necessary files to me, and compiling progect IDE has stopped working after compiling. I have a two output binary file, they are have a good structure(all what i need, binary file with icons and string have size 8,2 MB). But after that i can't open my project, i always see window "IDE stopped work". If I want open this project and work with him i must open the folder with project, and deleted all "object file", and "build file". Any way it inconvenient.
    Maybe you have some tips or solutions.
  • One interesting detail, today i create the same project in Keil uVision 4, and after compiling my project his create two binary file one of them 8.3MB(icon,fonts) and work good after that(don't stop working). As i understand this is a bug of IDE or something else. Can i fix it yourself?
    Sorry for my bad english.
    BR Ratibor
