SSP (SPI) debugging
Hi all,
I am trying to debug the SSP peripheral (in SPI mode)with Keil and I have a few questions about this.
First of all I would like to see how to view the contents of the frame buffer. If you use the Peripherals->SSP option of Keil you can't even see what is in the data register (SSP1DR) as it always defaults to zero.
Does anyone know how to solve this?
Also I am kind of confused on how exactly does the data move from the data register to the Frame Buffer. Does the data register hold the data at all or does it just shift them right out to the buffer?
And finally when I am running the program in debug mode and stepping commands one by one does the ssp peripheral still send data back and forth?
Thank you very much in advance.
With kind regards,
Sat
  • You didn't mention what chip. Extra interesting is that you specified architecture "Generic". Since when is SPI generic and not depending on selected chip?
    Anyway - Keil can't make wonders. Their JTAG adapter is limited to the behavior of the hardware. You aren't expected to be able to view the data register. If the debugger did access it, then the debugger would break the transfer by consuming received characters. So you have to settle for looking at the other registers.
    Frame buffer? Do you mean FIFO? You aren't expected to be able to see what is in the FIFO. Just look at flags to know if the FIFO is full, non-full, empty or non-empty.
    The SPI hardware will normally run even when you single-step. So it works well to debug the master side. But for the slave side you are likely to suffer serious buffer overruns/underruns when the program isn't emitting data to send or picking up received data fast enough because of the breakpoint.
  • Hi Per,
    Thanks for the quick reply.
    The reason why I chose non-specific and didn't specify the chip is because I thought that it was a general feature of any chip containing the SSP peripheral + Keil. The chip is NXP LPC1768 and it acts as a slave therefore I might be experiencing what you described when trying to debug through stepping in.
    As for the frame buffer you are correct I mean the FIFO but I don't understand why you shouldn't have at least read access to it. It might be useful.
    With kind regards,
    Sat
  • But "read access" to the FIFO would require that NXP - the chip maker - creates the FIFO using some form of dual-port RAM so that the JTAG adapter can view the FIFO without modifying any state.
    The top of the FIFO is visible to the program. And reading it will consume that element which is a very big reason why the debugger do not want to request the JTAG adapter to make a read of that address - there would be no way for the JTAG adapter to push back what it has consumed. So in the end, you need to ask NXP if they would be willing to add special access mechanisms in their chips - without dedicated hardware support in the chip, it will be the same for Keil, IAR, ...
    Note that specifying "generic" means that people who makes searches on this forum and selects ARM will not find this thread.
