About PCLK
I have bought a LandTiger development board for LPC1768. it has a 12Mhz Xtal on it. I am trying to use its USART0 and I need to know PCLK. is it 3MHz? I devide 12 by 4. am I right?
  • Any reason why you run the processor so extremely slow - are you running on batteries?
    The 12MHz crystal is normally first upscaled by a PLL so you might get a CCLK of 100MHz or something like that. But let's say the PLL is configured to scale the FOSC = 12MHz crystal giving a CCLK of 60MHz. Then a division by four would give the UART a PCLK of 60/4 = 15MHz.
  • Indeed I did not pay attention to the system_lpc17xx.c file where all the clock selection are listed.
    I see some values let me add it here:
    OSCRANGE=1 to 20 Mhz
    OSCEN enabled
    SLKSRC: Main Ocilator
    PLL0 multiplier selection: 100
    PLL0 Divider selection: 6
    CCLKSEL: divide value for CPU clock from PLL0 :4
    USART0: PCLK=CCLK/4
    PCON USART0 enabled.
    I dont understand what (divider selection=6) is!?
    is cpu clock 120Mhz? (100*12Mhz).
    is PCLK=120Mhz/4=30Mhz ?
  • PLL0_clk = (2 * M * FOSC) / N
    And CCLK is then the result of dividing PLL0_clk with a divider in CCLKSEL.
    It seems strange to have a PLL0 running at 100 times FOSC for a 12MHz FOSC, since 100*12MHz would be 1.2GHz and the PLL0 may not run faster than 550MHz.
  • Dear Arrogant,
    yes it is really large value for PLL0. I changed MSEL from 100 to 10. and NSEL is 6.
    therefore PLL0_clk=(2*10*12MHz)/6 which will be 40MHz.
    So that CCLK=10MHz
    PCLK=(CCLK/4)=2.5 MHz
    there for DLL= 2.5MHz/(16*9600) = 16.27 which is approximately 0x10
    I entered this in my code but USART0 is not working!
    void SER_init (int uart) {
      LPC_UART_TypeDef *pUart;
                                  /* UART0 */
        LPC_PINCON->PINSEL0 |= (1 << 4);
        LPC_PINCON->PINSEL0 |= (1 << 6);
        pUart = (LPC_UART_TypeDef *)LPC_UART0;
       pUart->LCR    = 0x83;                          /* 8 bits, no Parity, 1 Stop bit  */
       pUart->DLL    = 0x10;                             //BR=9600
       pUart->FDR    = 0x21;                          /* FR 1,507, DIVADDVAL = 1, MULVAL = 2 */
       pUart->DLM    = 0;                             /* High divisor latch = 0         */
       pUart->LCR    = 0x03;                          /* DLAB = 0                       */
  • Doesn't work, or works at a different speed than expected?
    So if you output a stream of characters (0x55) from UART0, and you review the signal on an oscilloscope what bit timing do you actually observe?
  • I don't have oscilloscope here. I tried different values for DLL but no character appears in the PC. I am sure about the connection coz I have tested serial port by another device.
  • Without oscilloscope you can always use a blinking LED with a timer or similar to verify your frequencies. Or if you have a multimeter with frequency measurement, you can have your UART send suitable characters and let the multimeter tell how many pulses/second it sees.
    Or run the UART without handshake and check how many characters/second it can send when you keep the transmit FIFO always non-empty.
    Note that NXP has an Excel spreadsheet with a lot of different PLL0 values where you enter your FOSC frequency and then can see the outcome of PLL frequency and resulting CCLK with different M, N and CPU divisor. And when you then have figured the settings to get a suitable CCLK, it's trivial to get the PCLK based on what PCLK divisor value you decide to set.
  • Hi
    I could see some unknown characters received in PC from USART0 of LPC1768. I know my DLL is not set well.
    I know I should give an exact DLL. my Xtal is 12 MHz. and other values are:
    PLL0 multiplier selection: M=10
    PLL0 Divider selection: N=2
    USART0: PCLK=CCLK/4
    How can I find CCLK?
    so that I find PCLK and get DLL from it.
  • I take it you haven't actually downloaded the PLL spreadsheet from NXP:s site?
    And you didn't try my formula either.
    PLL0 = 2 * M * FOSC / N = 2 * 10 * 12 / 2 = 120MHz.
    But the datasheet §5.1 says the PLL0 requires a frequency 275 - 550 MHz. 120MHz is much too low.
    Change M = 12
    Change N = 1
    Then you get PLL0 = 2*12*12/2 = 288MHz.
    With CPUDIV = 4, you then get CCLK = PLL0/4 = 288/4 = 72MHz
    With PCLK_DIV = 4, you then get PCLK = CCLK/4 = 72/4 = 18MHz.
    Then compute a suitable baudrate divisor to get your required baudrate.
    Or select a different set of M, N, CPUDIV and run the CCLK at a different speed - if I remember correctly, some LPC17xx manages 100MHz and some manages up to 120MHz.
    If you need really high UART baudrates, you might consider to use a lower PCLK_DIV to not get too large baudrate error from rounding error when computing the baudrate divisor - but that also depends on how high CCLK you configure.
  • Hi,
    you are right. I had the mistake. I followed your notes with M=12,N=1 and found DLL=117 or 0x75.
    But I don't receive any character in PC unless I give a value between 1 and 40 for DLL so I receive sth like ????? .
    It is confusing!
  • I think I have not set a proper value in FDR register. Do you have any idea how to set it? I dont understand what is the devideVAL[3:0] and mulVal[7:4]??
  • By try and error (I mean by using a for() loop) I found that the best values for DLL is 0x5 and for FDR is oxf5.
    by these values USART0 works well for Baudrate 9600. But my problem is not solved since I dont know how to config for other values of Baudrate!!! I need your kind help.
  • Try and error!? why? reading of the user manual is not more difficult than try and error. if you realize the structure of the PLL and clock section, you can set the desired baud rate with 0% error. in edition there is a configuration wizard in start up file that you can manage the system clock if you add it to your project.
