Hi, I get this error, The path is correct and also installed LwIp for TCP/IP. What esle should is do to get rid of this error. Tried various ways but failed. I am using examples programs from STM32F4DIS-BB Software Examples. Please help ASAP.
Below is the error. ..\src\netconf.c(36): error: #5: cannot open source input file "ethernetif.h": No such file or directory
Below is the Warning: ..\..\..\..\Utilities\Third_Party\lwip-1.4.1\src\core\tcp_out.c(845): warning: #550-D: variable "tcphdr" was set but never used struct tcp_hdr *tcphdr; ..\..\..\..\Utilities\Third_Party\lwip-1.4.1\src\core\tcp_out.c(1367): warning: #550-D: variable "tcphdr" was set but never used struct tcp_hdr *tcphdr;
Regards Mahesh Prasath.
If it's telling you that it can't open the file, you'd better check your assertion that the path is correct.
i crossed checked all but still the same
So in what directory is the file you claim exists?
