Hi, i'm using Keil MDK5 and have this error while compiling:
"send data.cpp: error: C3903U: Argument 'Cortex-M3' not permitted for option 'cpu'."
i couldn't find any solution for it, please advise me how can i solve this Problem. thanks.
There are 2 possibilites:
1. Refer below: http://www.keil.com/support/docs/3729.htm
2. You are using the evaluation/lite version.
If it is "2" then get in touch with a distributor to buy a license: http://www.keil.com/distis/
thanks for the answer. we have already license, so i think the issue is the first one. but where exactly do i Need to look for this file :" LLF5.0201305mdk_std37xxx7302xxxx919xxx" i searched a lot but couldn't find. thanks.
Get in touch with Keil Support team by raising you issue as per the procedure mentioned in below link: www2.keil.com/.../silver
Do not forget to mention your PSN/LIC and details about the issue.
