ARMCC bug
I think I have found a bug for ARMCC.
in my case, the correct result which would be:
VCMPE.F32 s0,s1
VMRS     APSR_nzcv,FPSCR
ITTT     LS
But actually, that was:
VCMPE.F32 s0,s1
ITT      LS
that was wrong for execute result also, and when i edited the bin file which is compiled and assemblied(change "ITT LS"(0xbf9c) to "ITTT LS"(0xbf9e)), everything looks correctly.
cortex-m4lf (you may see VMPE.F32 and VMRS)
  • That surely ranks highly in the worst bug reports ever!
    What compiler version?
    What source code produced the sequence?
    What compiler settings were used?
    etc. etc. etc
  • ARMCC 5.6.0.13 in KeilMDK 5.18.0.0
    source code likes (but not the same, and i am not sure this will be reproduct that)
    #define ARRAY_LENGTH 10
    float t0[ARRAY_LENGTH], t1;
    unsigned char i, arr[ARRAY_LENGTH], count;
    // do something, assign count, t0, t1, arr;
    for (i = 0; i < count; i++)
        if (arr[i] != 0)    // complier has changed these two statement.
            if (t0[i] < t1)    // complier has changed these two statement. and i donot know how complier make sure t1 is not NaN
                continue;
        // do something;
    VCMPE.F32 s0, s1
    ITT       LS            // here should be ITTT LS
    LDRBLS    lr, [r12, #0]
    CMPLS     lr #0
    BNE       #######       // so this BNE got the wrong flag Z
    Compiled by CLR with param "--c99 -c --cpu Cortex-M4.fp -g -O3 -Otime --apcs=interwork --split_sections" (no completely, but I think others are not the key)
    Thanks for your prompt reply!
    i will provide as more info as i can, but except complete source code. even now i cannot confirm is that a bug or just i got the wrong way to use.
    any way, thank you all again.
  • there is a mistake, not CLR, just command line.
  • source code likes (but not the same, and i am not sure this will be reproduct that)
    No point in anyone wasting time looking at it then.
    First lesson in hunting a bug: Try to reproduce it.
