Hello All
I am using pc-lint for the keil v5.14 [1] I want to add the 3 configuration files : [a]Base.lnt, [b]standard.lnt and [c]CO-RV.LNT. (Under Tools-->PC-Lint Options-->Configuration File: ) But under configuration file , I could add only 1 (one) file . Could you please tell how to add more files under the configuration files.
[2] Can PC-LINT Build Output be saved in Text Format OR any other format?. if yes , in which path PC-LINT build output(in any format) is saved ?. Do we need do any configuration setup to extract the PC-LINT build output ? Note: Build_log.htm file don’t have PC-LINT Build Output
Earliest Reply would be Appreciated . Kindly do the needful.
I can tell you there's no need to do that. PC-Lint files can pull in the contents of other such files already, simply by putting their name into them. See the PC-Lint documentation for the details.
Again, see the PC-Lint documentation.
