I have written a program for driving lCDusing 89S52 using keil . It is working in simulation but not displaying any thing on the target board In that program I have inserted a led blink code for knowing the program running status.The led is blinking means the code I have written is working .Then whats happening to my LCD part. Please any body suggest something.The crystal is 11.0592Mhz .....My code below
//delay.h// #ifndef __DELAY_H__ #define __DELAY_H__ void delay_us(unsigned int ); void delay_ms(unsigned int ); void delay_sec(unsigned char); void lcd_reset(); void LCD_Init(); void LCD_CmdWrite( char ); void LCD_DataWrite( char ); void LCD_GoToLineOne(); void LCD_GoToLineTwo(); void LCD_CmdWrite( char ); void LCD_GoToXY(char , char ); void LCD_DisplayString(char *string_ptr); void LCD_DisplayNumber(unsigned int ); void LCD_ScrollMessage(char *msg_ptr);
#endif
//delay.c// #include<reg52.h> /*---------------------------------------------------------------------------------- delay_us() void delay_us(unsigned int us_count) { while(us_count!=0) { us_count--; } } void delay_ms(unsigned int ms_count) { while(ms_count!=0) { delay_us(112); //delay_us is called to generate 1ms delay ms_count--; } }
void delay_sec(unsigned char sec_count) { while(sec_count!=0) { delay_ms(1000); //delay_ms is called to generate 1sec delay sec_count--; } } //D4-P0.4,D5-P0.5,D6-P0.6,D7-P0.7,RS-P0.0,RW-P0.1,EN-P0.2, #include<reg52.h> #include <delay.h> #define databus P2 // LCD databus connected to PORT2 sbit rs= databus^0; // Register select pin connected to P0.0 sbit rw= databus^1; // Read Write pin connected to P0.1 sbit en= databus^2; // Enable pin connected to P0.2 /* 16x2 LCD Specification */ #define LCDMaxLines 2 #define LCDMaxChars 16 #define LineOne 0x80 #define LineTwo 0xc0 #define BlankSpace ' ' void lcd_reset() { databus = 0xFF; delay_ms(20); databus = 0x34; databus = 0x30; delay_ms(10); databus = 0x34; databus = 0x30; delay_ms(1); databus = 0x34; databus = 0x30; delay_ms(1); databus = 0x24; databus = 0x20; delay_ms(1); } void LCD_Init() { //delay_us(5000); lcd_reset(); LCD_CmdWrite(0x02); //Initilize the LCD in 4bit Mode LCD_CmdWrite(0x28); LCD_CmdWrite(0x0E); // Display ON cursor ON LCD_CmdWrite(0x01); // Clear the LCD LCD_CmdWrite(0x80); // Move the Cursor to First line First Position }
void LCD_CmdWrite( char cmd) { databus=(cmd & 0xf0); // Send the Higher Nibble of the command to LCD rs=0; // Select the Command Register by pulling RS LOW rw=0; // Select the Write Operation by pulling RW LOW en=1; // Send a High-to-Low Pusle at Enable Pin delay_us(1); en=0; delay_us(10); // wait for some time databus=((cmd<<4) & 0xf0); // Send the Lower Nibble of the command to LCD rs=0; // Select the Command Register by pulling RS LOW rw=0; // Select the Write Operation by pulling RW LOW en=1; // Send a High-to-Low Pusle at Enable Pin delay_us(1); en=0; delay_ms(1); } void LCD_DataWrite( char dat) { databus=(dat & 0xf0); // Send the Higher Nibble of the Data to LCD rs=1; // Select the Data Register by pulling RS HIGH rw=0; // Select the Write Operation by pulling RW LOW en=1; // Send a High-to-Low Pusle at Enable Pin delay_us(1); en=0; delay_us(10); // wait for some time. databus=((dat <<4) & 0xf0); // Send the Lower Nibble of the Data to LCD rs=1; // Select the Data Register by pulling RS HIGH rw=0; // Select the Write Operation by pulling RW LOW en=1; // Send a High-to-Low Pusle at Enable Pin delay_us(1); en=0; delay_ms(1); } void LCD_DisplayString(char *string_ptr) { while(*string_ptr) LCD_DataWrite(*string_ptr++); } void LCD_DisplayNumber(unsigned int num) { LCD_DataWrite((num/10000)+0x30); num=num%10000; LCD_DataWrite((num/1000)+0x30); num=num%1000; LCD_DataWrite((num/100)+0x30); num=num%100; LCD_DataWrite((num/10)+0x30); LCD_DataWrite((num%10)+0x30); }
void LCD_ScrollMessage(char *msg_ptr) { unsigned char i,j; LCD_CmdWrite(0x0c); //Disable the Cursor for(i=0;msg_ptr[i];i++) //Loop to display the complete string { //each time 16 chars are displayed and //pointer is incremented to point to next char LCD_GoToLineOne(); //Move the Cursor to first line for(j=0; j<LCDMaxChars && msg_ptr[i+j];j++) //loop to Display first 16 Chars LCD_DataWrite(msg_ptr[i+j]); //or till Null char for(j=j; j<LCDMaxChars; j++) //If the chars are below 16 LCD_DataWrite(BlankSpace); //then display blank spaces delay_ms(125); } LCD_CmdWrite(0x0E); //Enable the Cursor } void LCD_GoToLineOne() { LCD_CmdWrite(LineOne); // Move the Cursor to First line First Position }
void LCD_GoToLineTwo() { LCD_CmdWrite(LineTwo); // Move the Cursor to Second line First Position }
void LCD_GoToXY(char row, char col) { char pos; if(row<LCDMaxLines) { pos= LineOne | (row << 6); // take the line number //row0->pos=0x80 row1->pos=0xc0 if(col<LCDMaxChars) pos= pos+col; //take the char number //now pos points to the given XY pos LCD_CmdWrite(pos); // Move the Cursor to specified Position } } //main.c// #include<reg52.h> #include <delay.h> main() { unsigned char k; LCD_Init() ; LCD_GoToLineOne(); LCD_DisplayString("**SUSHILA KUMAR**"); P1 = 255; while(1) { k = P1; delay_ms(250); P3 = 0; delay_ms(250); P3 = 255; LCD_GoToLineTwo(); LCD_DisplayNumber(k);
} kindly suggest me.........
Pity you didn't read the posting instructions.
Real hardware tends to be a lot more fussy about connectivity and timing. Start reviewing your design from there.
Please tell me how to review........I have checked the timing using a led blink code ....the on/off duration are observed to accurate.....
Please share some experience ...pls
Use an oscilloscope or logic analyzer to confirm the timing of the LCD signals with respect to the documentation for said LCD.
Thanks for suggestion ....but actually I have neither oscilloscope nor logic analyzer
Therefore I am in great trouble....
Can u test my code if u have oscilloscope.... I have no oscilloscope
And I don't have your hardware, or sufficient design/part info. Your code as presented is unreadable.
Some board you built, or a commercial design? Other working example code?
Review the documentation for your display, confirm you can read/write register on the LCD controller.
Break down the problem into smaller pieces you can solve yourself.
