sdcard detection
hello
i am working on a project using stm32f205, i am using the file system component v6.6 to
access an sdcard connected to the MCU via SDIO interface.
the sdcard reader i am using dont have card detection switch, so i have to check every time
if the card is present in the reader.
is there any function in the file system component v6.6 that let me do this process.
thanks
  • Maybe you can try to reinitialize the card in case this does not happen very often?
    int32_t drive_id = fs_ioc_get_id ("M0:");
    uint32_t arg = FS_CONTROL_MEDIA_INIT;
    if (fs_ioc_device_ctrl (drive_id, fsDevCtrlCodeControlMedia, &arg) == fsOK) {
      /* Memory media present */
    } else {
      /* Memory media removed */
  • hello
    thanks vladimir for the response.
    i have tried this method but now i have another problem.
    the sdcard is used by the USB MSC thread, and i have to place a semephore
    before checking the card.
    the problem is that i can not found the usb msc task functions.
    thanks
