ETM not working on stm32f7
i am using stm32f7 and for debugging ulink pro, i have tried to enable ETM but not succeeded.
the connector i am using is, where traceD0-D3 are PE3-PE6.
the *ini file i used is
01.
02.
** Define the function to enable the trace port
03.
04.
FUNC void EnableTPIU(void) {
05.
   _WDWORD(0xE0042004, 0x000000E0);    // Set 4-pin tracing via DBGMCU_CR
06.
//  _WDWORD(0xE0042004, 0x00000020);    // Set 4-pin tracing via DBGMCU_CR
07.
08.
    _WDWORD(0xE000EDFC, 0x01000000);    //
09.
    _WDWORD(0xE00400F0, 0x00000000);    //
10.
    _WDWORD(0xE0040004, 0x00000008);    //
11.
    _WDWORD(0xE0001020, 0x002002CA);    //
12.
    _WDWORD(0xE0001024, 0x0000000);    //
13.
    _WDWORD(0xE0001028, 0x00000008);    //
14.
15.
    _WDWORD(0xE0041004, 0x00000000);    //
16.
    _RDWORD(0xE004100C, 0x00000003);    //
17.
    _WDWORD(0xE0041040, 0x00000002);    //
18.
    _WDWORD(0xE0041080, 0x00000001);    //
19.
    _WDWORD(0xE004108C, 0x000000FF);    //
20.
    _WDWORD(0xE0041004, 0x00000001);    //
21.
22.
23.
24.
25.
** Invoke the function at debugger startup
26.
27.
EnableTPIU();
28.
29.
30.
** Execute upon software RESET
31.
32.
FUNC void OnResetExec(void)  {
33.
  EnableTPIU();
34.
which was given in reference manual as
40.15.4 Configuration example
To output a simple value to the TPIU:
• Configure trace I/Os: enable TRACE_CLKINEN in the STM32F75xxx and
STM32F74xxx debug configuration register (DBGMCU_CR).
• Write @ E000EDFC 01000000; SCS: set TRCENA, otherwise trace registers are not
accessible.
• Write @ E00400F0 00000000; TPIU: select SYNC PORT Mode
• Write @ E0040004 00000008; TPIU: select TPIU PORT SIZE=4
• Write @ E0001020 002002CA; WT: PC MATCH Comparator (PC=0x2002CA)
• Write @ E0001024 00000000; DWT: No mask apply on comparator
• Write @ E0001028 00000008; DWT: ETM trig on PC on match
ETM:
• Write @ E0041004 00000000; Disable ETM
• Read @ E004100C 00000003; ETM should be in Idle state
• Write @ E0041040 00000002; Instruction trace source ID = 0x2
• Write @ E0041080 00000001; Resource for ViewInst enabling event is “always
TRUE”
• Write @ E004108C 000000FF; Processor comparator selection for Start:
pc_match0 (=>DWT match)
• Write @ E0041004 00000001; Enable ETM
  • Hello Bilal,
    which development board are you using? I suppose the STM32F756G-EVAL. The latest Software Pack (2.4.0.) for the F7 devices has made the debug support easier. You do not need the ini file anymore.
    You should be able to use ETM by only selecting "Trace Enable" and "ETM Trace Enable" with the "Sync Trace Port with 4-bit Data" in the Target Driver Setup. In the next version we'll add a Quick Start Guide that shows that. Please note: You'll need to lower the target frequency as we won't be able to do ETM trace at 216 MHz.
    Kind regards,
    Christopher
  • Thank you Christopher for your reply.
    1.) i am using customized board, where pins i have assigned for trace are
    PC0 -> Trace_D0
    PC8 -> Trace_D1
    PD2 -> Trace_D2
    PC12 -> Trace_D3
    i downloaded 2.4.0 software pack, changed the core clock to 180 Mhz, removed the ini file, it didnot worked but then i pulled out wires from PE3 to PE6 and assigned them to Trace_D0 to Trace_D3 respectively, and trace started working perfectly.
    how can i get trace working on the assigned pins. i have also tried assigning these pins AF0 in ini file
    _WDWORD(0x40023830, _RDWORD(0x40023830) | 0x00000004); // RCC_AHB1ENR: IO port PC 1,8,12 clock enable
      _WDWORD(0x40021000,  0x02020008); // GPIOC_MODER:   PC1,PC8,PC12 = Alternate function mode
      _WDWORD(0x40021008, 0x0303000C);   // GPIOC_OSPEEDR: PC1,PC8 PC12  = 100 MHz speed
      _WDWORD(0x4002100C, 0x00000000);   // GPIOC_PUPDR:   PC1,PC8 PC12  = No Pull-up/Pull-down
      _WDWORD(0x40021020, 0x00000000);   // GPIOC_AFRL:    PC1,PC8 PC12  = AF0
      _WDWORD(0x40021024, 0x00000000);   // GPIOC_AFRH:    PC1,PC8 PC12  = AF0
      _WDWORD(0x40023830, _RDWORD(0x40023830) | 0x00000008); // RCC_AHB1ENR: IO port D2 clock enable
      _WDWORD(0x40021000, 0x00000002);   // GPIOD_MODER:   PD2 = Alternate function mode
      _WDWORD(0x40021008, 0x00000003);   // GPIOD_OSPEEDR: PD2 = 100 MHz speed
      _WDWORD(0x4002100C, 0x00000000);   // GPIOD_PUPDR:   PD2 = No Pull-up/Pull-down
      _WDWORD(0x40021020, 0x00000000);   // GPIOD_AFRL:    PD2 = AF0
    but that too didnot worked. can you guide me how can i initialize these pins so that i can get my trace (ETM) working.
    2.) in any case JTAG is not working, it only shows Unknown device detected, i am using a 2 layer board.
    thank you
    Bilal
  • Hello Bilal,
    at the moment, our debug description ties the trace pins to the PE* port. If you want to use the INI file method, you have to uncheck the Enable box on the Pack tab of the Cortex-M Target Driver Setup. This will give you the option to use the INI file method and define your trace pins as you see fit.
    Kind regards,
    Christopher
  • Thank you Christopher for your quick reply
    I unchecked Enable box on the Pack tab of the Cortex-M Target Driver Setup, included ini file but etm not working. i am adding my ini file, can you guide me where am i doing it wrong.
     _RDWORD(0xE004100C, _RDWORD(0xE004100C) |  0x00000003);   //
    EnableTPIU();
      EnableTPIU();
    2.) can you tell why JTAG is not working for stm32f7,instead it is working for stm32f4.
    thank you and regards
    Bilal
  • Hello Bilal,
    can you please contact support regarding this issue?
    Kind regards,
    Christopher
  • Hello Bilal,
    I would like to continue this discussion via our support channel. I might have a solution for your problem.
    Kind regards,
    Christopher
  • Thank you christopher, my problem is still unsolved. Can you guide me, how can i write ini file according to assigned pins.
    Thank you so much
    Bilal
  • Hello Bilal,
    please contact support: support.intl@keil.com and refer to this forum thread.
    Kind regards,
    Christopher
  • Hello,
    I'm working on a custom board using STM32F765 and want to use ULINKpro+ETM.
    Did you find a solution for your problem?
    What max. core clock is possible with ETM enabled?
    Thank you.
