I am unable to properly update my IDE (details below) to recognize evaluation board Discovery STM32F334. I get following errors: This project references devices, files or libraries that are not installed. Downloadd and Install:
Third Party Device Support for 'STMicoroelectronics: STM32F334C8' (Device not included in legacy Device Database)
and
Error: Device not found-
Device : 'STM32F334C8' Vendor : 'STMicroelectronics'
Please update your device selection.
However my Pack Installer in Devices tab contains STM32F334C8 In Boards tab Discovery STM32F334 does not appear.
How can I have run Check for updates Also imported Keil.STM32F3xx_DFP.1.3.0.pack
In the Options for Target dialog, Device tab STM32F334 is still missing.
I see that on the website keil supports: STM32F3-Discovery STM32F303VC STM32F303
I could not find support packs on ST website for 32F3348DISCOVERY.
Any advice on how to proceed is greatly appreciated.
IDE-Version: µVision V5.20.0.0
What license have you used to register your MDK? If it is the free MDK license for for STM32L0 and STM32F0 from here www2.keil.com/.../ , then you cannot see the STM32F3 in the device option
I may have used a wrong PSN, and I got my pro license later.
What can I do now?
IDE-Version: µVision V5.20.0.0 Copyright (C) 2016 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information: Arkady Kogan Phoenix Contact
Tool Version Numbers: Toolchain: MDK-ARM Professional Version: 5.20
as long as you register your MDK with your pro license successfully, after installing the DFP, you should be able to see the STM32F334x in the Device Option of µVision.
all devices supported by MDK can be found here: http://www.keil.com/dd2/ http://www.keil.com/dd/
How do I re-register?
