Hello everybody,
Sorry for my english.
I start a new prog, and so I am at the beging. This the first time that I include assembler code in a program write in C.
When I build all targets I have 2 warnings :
- Warning L1: Unresolved external symbol Symbol: ?C_START Module: STARTUP.obj (?C_STARTUP)
and
- Warning L2: Reference made to unresolved external Symbol: ?C_START Module: STARTUP.obj (?C_STARTUP) Address: 205FH
I read the help of Keil, but it does not do me much.
Note that I validated "Generate Assembler SRC File" in the option of main.c and in the option of "Source Group 1".
In the "source group 1" I have 2 files "main.c" and "STARTUP.A51"
Please find this two files :
main.c :
#include <REG51.H> void ecriture_flash(); void main() { unsigned char unite; unsigned char dizaine; unsigned char centaine; #pragma asm ORG 0000h JMP 2000h ORG 2000h #pragma endasm SM0=0; //UART en mode 1 SM1=1; //UART en mode 1 SM2=0; //Gestion multiprocesseur inactive REN=1; //Reception active TMOD=0x20; //Config Timer 1 en mode 2 et mode temporisateur TH1=255; //56000 Bauds TR1=1; //Active le timer 1 TI=0; centaine='3'; dizaine='2'; unite='1'; DPH=0xFF; DPL=0xFF; ACC=centaine; ecriture_flash(); DPH=0xFF; DPL=0xFE; ACC=dizaine; ecriture_flash(); DPH=0xFF; DPL=0xFD; ACC=unite; ecriture_flash(); DPH=0xFF; DPL=0xFC; ACC=0xDD; ecriture_flash(); while (1); } void ecriture_flash() { #pragma asm MOV R1, #02h MOV 0B1h, #0 //Cette commande et les 2 suivantes doivent obligatoirement être placé après l'adresse ORG 2000h, sinon destruction du uC CALL 1FF0h MOV 0B1h, #1 #pragma endasm }
and STARTUP.A51 :
$NOMOD51 ;------------------------------------------------------------------------------ ; This file is part of the C51 Compiler package ; Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc. ; Version 8.01 ; ; *** <<< Use Configuration Wizard in Context Menu >>> *** ;------------------------------------------------------------------------------ ; STARTUP.A51: This code is executed after processor reset. ; ; To translate this file use A51 with the following invocation: ; ; A51 STARTUP.A51 ; ; To link the modified STARTUP.OBJ file to your application use the following ; Lx51 invocation: ; ; Lx51 your object file list, STARTUP.OBJ controls ; ;------------------------------------------------------------------------------ ; ; User-defined <h> Power-On Initialization of Memory ; ; With the following EQU statements the initialization of memory ; at processor reset can be defined: ; ; <o> IDATALEN: IDATA memory size <0x0-0x100> ; Note: The absolute start-address of IDATA memory is always 0 ; The IDATA space overlaps physically the DATA and BIT areas. IDATALEN EQU 80H ; ; <o> XDATASTART: XDATA memory start address <0x0-0xFFFF> ; The absolute start address of XDATA memory XDATASTART EQU 0 ; ; <o> XDATALEN: XDATA memory size <0x0-0xFFFF> ; The length of XDATA memory in bytes. XDATALEN EQU 0 ; ; <o> PDATASTART: PDATA memory start address <0x0-0xFFFF> ; The absolute start address of PDATA memory PDATASTART EQU 0H ; ; <o> PDATALEN: PDATA memory size <0x0-0xFF> ; The length of PDATA memory in bytes. PDATALEN EQU 0H ; ;</h> ;------------------------------------------------------------------------------ ; ;<h> Reentrant Stack Initialization ; ; The following EQU statements define the stack pointer for reentrant ; functions and initialized it: ; ; <h> Stack Space for reentrant functions in the SMALL model. ; <q> IBPSTACK: Enable SMALL model reentrant stack ; Stack space for reentrant functions in the SMALL model. IBPSTACK EQU 0 ; set to 1 if small reentrant is used. ; <o> IBPSTACKTOP: End address of SMALL model stack <0x0-0xFF> ; Set the top of the stack to the highest location. IBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1 ; </h> ; ; <h> Stack Space for reentrant functions in the LARGE model. ; <q> XBPSTACK: Enable LARGE model reentrant stack ; Stack space for reentrant functions in the LARGE model. XBPSTACK EQU 0 ; set to 1 if large reentrant is used. ; <o> XBPSTACKTOP: End address of LARGE model stack <0x0-0xFFFF> ; Set the top of the stack to the highest location. XBPSTACKTOP EQU 0xFFFF +1 ; default 0FFFFH+1 ; </h> ; ; <h> Stack Space for reentrant functions in the COMPACT model. ; <q> PBPSTACK: Enable COMPACT model reentrant stack ; Stack space for reentrant functions in the COMPACT model. PBPSTACK EQU 0 ; set to 1 if compact reentrant is used. ; ; <o> PBPSTACKTOP: End address of COMPACT model stack <0x0-0xFFFF> ; Set the top of the stack to the highest location. PBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1 ; </h> ;</h> ;------------------------------------------------------------------------------ ; ; Memory Page for Using the Compact Model with 64 KByte xdata RAM ; <e>Compact Model Page Definition ; ; Define the XDATA page used for PDATA variables. ; PPAGE must conform with the PPAGE set in the linker invocation. ; ; Enable pdata memory page initalization PPAGEENABLE EQU 0 ; set to 1 if pdata object are used. ; ; <o> PPAGE number <0x0-0xFF> ; uppermost 256-byte address of the page used for PDATA variables. PPAGE EQU 0 ; ; <o> SFR address which supplies uppermost address byte <0x0-0xFF> ; most 8051 variants use P2 as uppermost address byte PPAGE_SFR DATA 0A0H ; ; </e> ;------------------------------------------------------------------------------ ; Standard SFR Symbols ACC DATA 0E0H B DATA 0F0H SP DATA 81H DPL DATA 82H DPH DATA 83H NAME ?C_STARTUP ?C_C51STARTUP SEGMENT CODE ?STACK SEGMENT IDATA RSEG ?STACK DS 1 EXTRN CODE (?C_START) PUBLIC ?C_STARTUP CSEG AT 0 ?C_STARTUP: LJMP STARTUP1 RSEG ?C_C51STARTUP STARTUP1: IF IDATALEN <> 0 MOV R0,#IDATALEN - 1 CLR A IDATALOOP: MOV @R0,A DJNZ R0,IDATALOOP ENDIF IF XDATALEN <> 0 MOV DPTR,#XDATASTART MOV R7,#LOW (XDATALEN) IF (LOW (XDATALEN)) <> 0 MOV R6,#(HIGH (XDATALEN)) +1 ELSE MOV R6,#HIGH (XDATALEN) ENDIF CLR A XDATALOOP: MOVX @DPTR,A INC DPTR DJNZ R7,XDATALOOP DJNZ R6,XDATALOOP ENDIF IF PPAGEENABLE <> 0 MOV PPAGE_SFR,#PPAGE ENDIF IF PDATALEN <> 0 MOV R0,#LOW (PDATASTART) MOV R7,#LOW (PDATALEN) CLR A PDATALOOP: MOVX @R0,A INC R0 DJNZ R7,PDATALOOP ENDIF IF IBPSTACK <> 0 EXTRN DATA (?C_IBP) MOV ?C_IBP,#LOW IBPSTACKTOP ENDIF IF XBPSTACK <> 0 EXTRN DATA (?C_XBP) MOV ?C_XBP,#HIGH XBPSTACKTOP MOV ?C_XBP+1,#LOW XBPSTACKTOP ENDIF IF PBPSTACK <> 0 EXTRN DATA (?C_PBP) MOV ?C_PBP,#LOW PBPSTACKTOP ENDIF MOV SP,#?STACK-1 ; This code is required if you use L51_BANK.A51 with Banking Mode 4 ;<h> Code Banking ; <q> Select Bank 0 for L51_BANK.A51 Mode 4 #if 0 ; Initialize bank mechanism to code bank 0 when using L51_BANK.A51 with Banking Mode 4. EXTRN CODE (?B_SWITCH0) CALL ?B_SWITCH0 ; init bank mechanism to code bank 0 #endif ;</h> LJMP ?C_START END
Do you have an idea ?
Already answered here: http://www.keil.com/forum/58545/
Why do you think it necessary to format your enire text in bold?
Bold should be reserved for emphasis...
