STM32F4 cannot access input capture interupt
please look at the code below and tell me what wrong with the configuration. I used Stm32f4 discovery kit, and generated PWM via PC6, then connected it to PE11. However, no interupt occurred.
/*set the led to check if interrupt was access
void TIM1_CC_IRQHandler(void)
  if(TIM_GetITStatus(TIM1, TIM_IT_CC2) == SET)
                GPIO_SetBits(GPIOD,GPIO_Pin_15);
    /* Clear TIM1 Capture compare interrupt pending bit */
    TIM_ClearITPendingBit(TIM1, TIM_IT_CC2);
int main(void)
  TIM3_Config();
  PWM_TIM3_output();
  TIM1_Config();
  TIMICI_config();
  Output_Configuration();//for blue led - GPIOD 15
  while (1){}
void TIMICI_config(void)
  TIM_ICInitTypeDef  TIM_ICInitStructure;
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_ICInit(TIM1, &TIM_ICInitStructure);
  TIM_PWMIConfig(TIM1, &TIM_ICInitStructure);
  /* Select the TIM1 Input Trigger: TI2FP2 */
  TIM_SelectInputTrigger(TIM1, TIM_TS_TI2FP2);
  /* TIM enable counter */
  TIM_Cmd(TIM1, ENABLE);
  /* Enable the CC2 Interrupt Request */
  TIM_ITConfig(TIM1, TIM_IT_CC2, ENABLE);
void TIM1_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
/* TIM1 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
/* GPIOE clock enable */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
/* TIM1 chennel2 configuration : PE.11 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ; GPIO_Init(GPIOE, &GPIO_InitStructure);
/* Connect TIM pin to AF2 */ GPIO_PinAFConfig(GPIOE, GPIO_PinSource11, GPIO_AF_TIM1);
/* Enable the TIM1 global Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); }
