MDK5 NAND Page Data Layout setting
Hello.
I am using MDK5 now. (stm32f2xx)
When I used MDK4 before, I set nand configuration for NAND Page Data Layout.
static U32 Init (NAND_DRV_CFG *cfg) {
/* Setup OneNAND Page Layout */ cfg->PgLay->Pos_LSN = 2; cfg->PgLay->Pos_COR = 1; cfg->PgLay->Pos_BBM = 0; cfg->PgLay->Pos_ECC = 8; cfg->PgLay->SectInc = 512; cfg->PgLay->SpareOfs = 2048; cfg->PgLay->SpareInc = 16;
/* Init NAND Driver Peripheral */ /* ... */ return RTV_NOERR;
http://www.keil.com/support/man/docs/rlarm/rlarm_fs_cfgspare.htm
Can I use nand configuration in MDK5?
  • This structure can control much of the page layout, in MDK 5:
    www.keil.com/.../group__nand__interface__gr.html
  • I wrote a programming like this.
    extern ARM_DRIVER_NAND Driver_NAND0;
    ARM_DRIVER_NAND *drv_info;
    void setup_nand (void)
    { ARM_NAND_ECC_INFO info;
    drv_info = &Driver_NAND0;
    drv_info->InquireECC (0, &info);
    Structure 'info' got NAND ECC Information using InquireECC function.
    Can I set NAND ECC Information using InquireECC function?
  • No, you cannot set it, its the other way around. NAND driver must provide ARM_NAND_ECC_INFO structure and middleware then examines that structure using something similar to:
      ARM_DRIVER_NAND  *drv;
      ARM_NAND_ECC_INFO ecc;
      uint32_t          idx;
      idx = 0;
      while (drv->InquireECC (idx++, &ecc) == ARM_DRIVER_OK) {
        /* Some smart processing of ARM_NAND_ECC_INFO structure inside loop */
    ARM_NAND_ECC_INFO structure is meant as a description of driver ECC capabilities to the middleware, therefore the driver needs to provide that info, middleware examines it and sets appropriate page layout.
  • extern ARM_DRIVER_NAND Driver_NAND0;
    { ARM_NAND_ECC_INFO info; int temp=0 ;
    temp = drv_info->InquireECC (0, &info) ;
    printf ("temp = %d\r\n", temp);
    result :
    temp = -4
    www.keil.com/.../group__execution__status.html
    #define ARM_DRIVER_ERROR_UNSUPPORTED -4
    Operation not supported.
    The function requested an operation (for example by using an illegal control code) that is not supported.
    Does it mean that InquireECC is not supported?
  • Yes, apparently its not supported.
    What are you actually trying to achieve and which driver do you use?
  • I use uVision V5.17.0.0 and CMSIS Driver(Memory Bus)
      /* Setup NAND Page Layout */
      cfg->PgLay->Pos_LSN  = 0;
      cfg->PgLay->Pos_COR  = 4;
      cfg->PgLay->Pos_BBM  = 5;
      cfg->PgLay->Pos_ECC  = 6;
      cfg->PgLay->SectInc  = 540;       // very important
      cfg->PgLay->SpareOfs = 512;       // very important
      cfg->PgLay->SpareInc = 540;       // very important
      return RTV_NOERR;
    I need to set SectInc value, SpareOfs value, SpareInc value.
  • You don't need to do that for memory bus driver - just enable Software ECC and you are done. Middleware will use default page layout for such case, because it does not need to worry about ECC placement by hardware controller.
  • I modified a FS_Config_NAND_0.h like this
    Connect to hardware via Driver_NAND#     : 0
    Device Number                            : 0
    Bus Width                                : 8-bit
    Page Size                           : 4096+244 bytes   // special setting. not default
    Block Size                               : 64 pages
    Device Size[blocks]                      : 4096
    Page Caching                             : 8 pages
    Block indexing                           : 16 blocks
    Software ECC                             : Hamming (SLC)
    Drive Cache Size                         : 8 KB
    and I programmed the sample like this
    finit ("N0:");
    printf("finit = 0x%x\r\n",stat) ;
    fmount ("N0:");
    printf("fmount = 0x%x\r\n",stat) ;
    stat = 0 ;
    opt = "/FAT32";
    stat = fformat ("N0:",opt) ;
    printf("fformat = 0x%x\r\n",stat) ;
    result :
    finit = 0x0
    fmount = 0x9
    fformat = 0x9
    #define fsMediaError    0x09       // Media error
    I don't know why I can not format a NAND Filesystem in KEIL5(MDK5).
    But I succeeded to format a NAND Filesystem using a NAND Page Data Layout in KEIL4(MDK4).
  • Did you make sure, that you have your external memory controller properly configured?
  • I used a Micron NAND(MT29F8G08ABACA / 1GByte) and its features is like this
    - Page size x8: 4320 bytes (4096 + 224 bytes)
    – Block size: 64 pages (256K + 14K bytes)
    – Device size: 8Gb: 4096 blocks
    1 page = (4K + 224 bytes)
    1 block = (4K + 224) bytes x 64 pages
            = (256K + 14K) bytes
    Minimum required ECC : 8-bit ECC per 540 bytes of data
