Libs, weak references and toolchain magic
I am attempting to build a .lib for a hardware abstract layer. Two related questions:
1) The library handles several interrupts (e.g. faults, gpio). However, I find that fault handling is being routed back to the default weak implementations in any program that links with the library. How do I ensure that the library implementations are used by the linker?
2) More generally, are there other factors I should be aware of when producing a .lib that abstracts toolchain "magic" (e.g. RTX, startup_XXX.s, SVC_Table.s) from the main executable?
Thanks,
Chris
0
