STM32 SDRAM Scatter File
i have the following problem:
I would like to access the external SDRAM on the STM32F429 Discovery. I could access the external SDRAM, that is not the main problem. The problem is, that i have to access the external SDRAM as the following:
 /* SDRAM Initialization */
  SDRAM_Init();
  /* FMC SDRAM GPIOs Configuration */
  SDRAM_GPIOConfig();
//Write SDRAM
  for (counter = 0; counter < TRANSFERS; counter++)
    *(__IO uint16_t*) (SDRAM_BANK_ADDR + 2*counter) = (uint16_t)(uhWritedata_16b + counter);
Here i havé to add the Address "SDRAM_BANK_ADDR" if i would like to write into the external SDRAM. Now i should configure the Scatter - File that i doesn't need that Section. How must be the changes? Is it possible to auto - configure this Section as external SDRAM?
My Scatter File looks like this:
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x08000000 0x00200000  {    ; load region size_region
  ER_IROM1 0x08000000 0x00200000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM1 0x20000000 0x00030000  {  ; RW data
   .ANY (+RW +ZI)
;LR_ERAM1 0xD0000000 0xD0400000 {
        ;ER_ERAM1 0xD0000000 0xD0400000  {
          ;.ANY (+RW +ZI)
Thanks for your help.
  • It's specified in the Scatter File as a SIZE, not by an end address.
    So 0xD0000000 0x400000
    If you use it in the linker, then you'd had better initialize the external memory interface and SDRAM in the SystemInit() routine so the C run time code can copy statics into the SDRAM
    You can access the SDRAM with pointers, make absolute declarations, or put the heap there.
    unsigned char *FrameBuffer = (unsigned char *)0xD0100000;
  • 's specified in the Scatter File as a SIZE, not by an end address. So 0xD0000000 0x400000
    Thanks for your explanation, so i have to change the Scatter File right? How should it looks like?
    Could you make an example? I don't understand it... Here you can see my System Init Function, what kind of changes should be done?
    /* FPU settings ------------------------------------------------------------*/
      #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
        SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2));  /* set CP10 and CP11 Full Access */
      #endif
      /* Reset the RCC clock configuration to the default reset state ------------*/
      /* Set HSION bit */
      RCC->CR |= (uint32_t)0x00000001;
      /* Reset CFGR register */
      RCC->CFGR = 0x00000000;
      /* Reset HSEON, CSSON and PLLON bits */
      RCC->CR &= (uint32_t)0xFEF6FFFF;
      /* Reset PLLCFGR register */
      RCC->PLLCFGR = 0x24003010;
      /* Reset HSEBYP bit */
      RCC->CR &= (uint32_t)0xFFFBFFFF;
      /* Disable all interrupts */
      RCC->CIR = 0x00000000;
    #if defined (DATA_IN_ExtSDRAM)
      SystemInit_ExtMemCtl();
    #endif /* DATA_IN_ExtSDRAM */
      /* Configure the System clock source, PLL Multiplier and Divider factors,
         AHB/APBx prescalers and Flash settings ----------------------------------*/
      SetSysClock();
      /* Configure the Vector Table location add offset address ------------------*/
    #ifdef VECT_TAB_SRAM
      SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
    #else
      SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
    #endif
    I understand this example, but i could not use it for my project, becouse i would write in the external SDRAM like in the normal RAM, i will not make defines for the Adress Section. So it means that i would access the external SDRAM like the normal RAM - that is what i need
  • See that DATA_IN_ExtSDRAM define, and the SystemInit_ExtMemCtl() function it calls? Define it, and make sure the routine initializes your SDRAM
    LR_IROM1 0x08000000 0x00200000  {    ; load region size_region (2M)
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      RW_IRAM1 0x20000000 0x00030000  {  ; RW data (192K)
       .ANY (+RW +ZI)
      RW_IRAM2 0xD0000000 0x00400000  {  ; SDRAM (4M)
       startup_stm32f429_439xx.o (HEAP)
       *(.sdram)
    char buf[256] __attribute__ ((section(".sdram")));
    The SDRAM is within regular memory space, but is slower.
    Keil project toward the end of this thread.
    my.st.com/.../Flat.aspx
  • First Thanks for your Help
    Where should be the changes? In which File i should make the #DEFINE DATA_IN_ExtSDRAM and what kind of changes are there? Where should i implement the SystemInit_ExtMemCtl (In the startup_stm32f429_439xx.s - File?) and how should it look?
    LR_IROM1 0x08000000 0x00200000 { ; load region size_region (2M) ER_IROM1 0x08000000 0x00200000 { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } RW_IRAM1 0x20000000 0x00030000 { ; RW data (192K) .ANY (+RW +ZI) } RW_IRAM2 0xD0000000 0x00400000 { ; SDRAM (4M) startup_stm32f429_439xx.o (HEAP) *(.sdram) }
    Thanks for this Example
    This variable i have to define in my main.c - File right?
    I don't want to use the external SDRAM as my regular memory space - i only wanna access it in a flexible and easy way without any functions or something else
    The Link doesn't work for me
    Keil project toward the end of this thread. my.st.com/.../Flat.aspx
  • Try this
    http://goo.gl/XDTOdJ
    or
    Google "STM32F429DISCO EXTERNAL RAM"
    There seems to be a basic lack of comprehension. The Internal SRAM is situated at 0x20000000 and above, the external SDRAM at 0xD0000000, your can access EITHER without functions, they live in the same 4GB/32-bit memory map of the micro-processor. They are not mysteriously different.
    The define is within the same system_stm32f4xx.c source as the SystemInit() function, and the external memory configuration routine. Use "Find in File" or "Go to Definition". This is a project specific file, tailored to your hardware. There is a Keil example of this file for the STM32F429I-DISCO board at the end of the cited thread.
    The memory needs to get configured prior to use by the C compiler's run time code, as if you describe the available memory in the scatter file and put statics there, they will need to be initialized or zeroed. If the FMC hasn't been configured the system will Hard Fault.
    A lot of these concepts should be covered in "Assemblers, Compilers, Linkers, and Loaders" type books and classes.
    You want to be selective about what you put in this external memory because it's decidedly slower than internal SRAM. Like I said, you can direct specific variables into specific sections/segments, you can put the HEAP in this memory, and allocate that, or use pointers. This isn't distinctly different from any other C use of memory. You just need to be a little selective about which area of memory you want to use for different purposes. If you put the STACK in SDRAM it will make everything SLOWER.
  • There seems to be a basic lack of comprehension. The Internal SRAM is situated at 0x20000000 and above, the external SDRAM at 0xD0000000, your can access EITHER without functions, they live in the same 4GB/32-bit memory map of the micro-processor. They are not mysteriously different.
    I don't understand this step - I find the SystemInit() - Function but what kind of changes must be done? If made a define -> #define DATA_IN_ExtSDRAM there, but no changes
    void SystemInit(void)
      #endif
      /* Set HSION bit */
      SetSysClock();
    #else
    #endif
    My Scatterfile looks like this one:
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
       .ANY (+RW +ZI)
      ;RW_ERAM1 0xD0000000 0x00400000  {
            ;startup_stm32f429_439xx.o (HEAP)
            ;*(.sdram)
    Now i would like to access the Section .sdram like something like this:
    uint32_t buf[256] __attribute__ ((section(".sdram")));
    What is incorrect in my handling?
    Can you give me some code examples?
  • Didn't I provide a thread short cut in my last response? Towards the end of the thread is a message with an attachment containing a Keil example. If the shortened link doesn't work there is also a Google search term to find the thread in question. I've tried very hard to provide multiple ways to get the information you want.
    It has a system_stm32f4xx.c file with the right defines and subroutines to enable the SDRAM on the board. It's all been modified to suit the STM32F429I-DISCO board.
    You have commented out the portion of the scatter file dealing with the SDRAM. The code to enable the external memory has to deal with your specific board/parts, if you didn't add or adjust the code to suit it probably won't work. The size of the heap is defined in the startup_stm32f4xx.s file.
  • Didn't I provide a thread short cut in my last response? [...] I've tried very hard to provide multiple ways to get the information you want.
    Thanksfull for your help - but sometime it's a little bit hard to understand
    It has a system_stm32f4xx.c file [...] board.
    I think i did the right defines in system_stm32f4xx.c -> My defines are the following in this file, i think they are correct for the STM32F429 DISCO:
    /* #define VECT_TAB_SRAM */
    #define VECT_TAB_OFFSET  0x00
    //#define PLL_SOURCE_HSI        // HSI (~16 MHz) used to clock the PLL, and the PLL is used as system clock source
    #define PLL_SOURCE_HSE        // HSE (8MHz) used to clock the PLL, and the PLL is used as system clock source
    //#define PLL_SOURCE_HSE_BYPASS   // HSE bypassed with an external clock (8MHz, coming from ST-Link) used to clock
                                    // the PLL, and the PLL is used as system clock source
    /* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
    #if defined  (PLL_SOURCE_HSI)
    #define PLL_M      16
    #else
    #define PLL_M      8
    #endif
    #define PLL_N      360
    /* SYSCLK = PLL_VCO / PLL_P */
    #define PLL_P      2
    /* USB OTG FS, SDIO and RNG Clock =  PLL_VCO / PLLQ */
    #define PLL_Q      7
    I have no idea what i have to change in my startup file - when i try it like before i could see in the Map-File that the Variable should be accessable. Here is a short piece from my current Map-File. (Here you can see the Variable buf - it should be stored in the external sdram / you also can see the execution region .sdram)
    t_buffer                                 0x2000002c   Data        4000  main.o(.bss)
    r_buffer                                 0x20000fcc   Data        4000  main.o(.bss)
    __libspace_start                         0x20001f6c   Data          96  libspace.o(.bss)
    __temporary_stack_top$libspace           0x20001fcc   Data           0  libspace.o(.bss)
    buf                                      0xd0000000   Data        1024  main.o(.sdram)
    Execution Region RW_ERAM1 (Base: 0xd0000000, Size: 0x00000400, Max: 0x00400000, ABSOLUTE, COMPRESSED[0x0000000c])
        Base Addr    Size         Type   Attr      Idx    E Section Name        Object
        0xd0000000   0x00000400   Data   RW         2892    .sdram              main.o
  • I will give you here my startup-file, i hope you can tell me what exactlly should change and how i should change it.
    Stack_Size      EQU     0x00000400
                    AREA    STACK, NOINIT, READWRITE, ALIGN=3
    Stack_Mem       SPACE   Stack_Size
    __initial_sp
    Heap_Size       EQU     0x00000200
                    AREA    HEAP, NOINIT, READWRITE, ALIGN=3
    __heap_base
    Heap_Mem        SPACE   Heap_Size
    __heap_limit
                    PRESERVE8
                    THUMB
    ; Vector Table Mapped to Address 0 at Reset
                    AREA    RESET, DATA, READONLY
                    EXPORT  __Vectors
                    EXPORT  __Vectors_End
                    EXPORT  __Vectors_Size
    __Vectors
    DCD     WWDG_IRQHandler
    DCD     PVD_IRQHandler
    DCD     TAMP_STAMP_IRQHandler
    DCD     RTC_WKUP_IRQHandler
    DCD     FLASH_IRQHandler
    DCD     RCC_IRQHandler
    DCD     EXTI0_IRQHandler
    DCD     EXTI1_IRQHandler
    DCD     EXTI2_IRQHandler
    DCD     EXTI3_IRQHandler
    DCD     EXTI4_IRQHandler
    DCD     DMA1_Stream0_IRQHandler
    DCD     DMA1_Stream1_IRQHandler
    DCD     DMA1_Stream2_IRQHandler
    DCD     DMA1_Stream3_IRQHandler
    DCD     DMA1_Stream4_IRQHandler
    DCD     DMA1_Stream5_IRQHandler
    DCD     DMA1_Stream6_IRQHandler
    DCD     ADC_IRQHandler
    DCD     CAN1_TX_IRQHandler
    DCD     CAN1_RX0_IRQHandler
    DCD     CAN1_RX1_IRQHandler
    DCD     CAN1_SCE_IRQHandler
    DCD     EXTI9_5_IRQHandler
    DCD     TIM1_BRK_TIM9_IRQHandler
    DCD     TIM1_UP_TIM10_IRQHandler
    DCD     TIM1_TRG_COM_TIM11_IRQHandler
    DCD     TIM1_CC_IRQHandler
    DCD     TIM2_IRQHandler
    DCD     TIM3_IRQHandler
    DCD     TIM4_IRQHandler
    DCD     I2C1_EV_IRQHandler
    DCD     I2C1_ER_IRQHandler
    DCD     I2C2_EV_IRQHandler
    DCD     I2C2_ER_IRQHandler
    DCD     SPI1_IRQHandler
    DCD     SPI2_IRQHandler
    DCD     USART1_IRQHandler
    DCD     USART2_IRQHandler
    DCD     USART3_IRQHandler
    DCD     EXTI15_10_IRQHandler
    DCD     RTC_Alarm_IRQHandler
    DCD     OTG_FS_WKUP_IRQHandler
    DCD     TIM8_BRK_TIM12_IRQHandler
    DCD     TIM8_UP_TIM13_IRQHandler
    DCD     TIM8_TRG_COM_TIM14_IRQHandler
    DCD     TIM8_CC_IRQHandler
    DCD     DMA1_Stream7_IRQHandler
    DCD     FMC_IRQHandler
    DCD     SDIO_IRQHandler
    DCD     TIM5_IRQHandler
    DCD     SPI3_IRQHandler
    DCD     UART4_IRQHandler
    DCD     UART5_IRQHandler
    DCD     TIM6_DAC_IRQHandler
    DCD     TIM7_IRQHandler
    DCD     DMA2_Stream0_IRQHandler
    DCD     DMA2_Stream1_IRQHandler
    DCD     DMA2_Stream2_IRQHandler
    DCD     DMA2_Stream3_IRQHandler
    DCD     DMA2_Stream4_IRQHandler
    DCD     ETH_IRQHandler
    DCD     ETH_WKUP_IRQHandler
    DCD     CAN2_TX_IRQHandler
    DCD     CAN2_RX0_IRQHandler
    DCD     CAN2_RX1_IRQHandler
    DCD     CAN2_SCE_IRQHandler
    DCD     OTG_FS_IRQHandler
    DCD     DMA2_Stream5_IRQHandler
    DCD     DMA2_Stream6_IRQHandler
    DCD     DMA2_Stream7_IRQHandler
    DCD     USART6_IRQHandler
    DCD     I2C3_EV_IRQHandler
    DCD     I2C3_ER_IRQHandler
    DCD     OTG_HS_EP1_OUT_IRQHandler
    DCD     OTG_HS_EP1_IN_IRQHandler
    DCD     OTG_HS_WKUP_IRQHandler
    DCD     OTG_HS_IRQHandler
    DCD     DCMI_IRQHandler
    DCD     CRYP_IRQHandler
    DCD     HASH_RNG_IRQHandler
    DCD     FPU_IRQHandler
    DCD     UART7_IRQHandler
    DCD     UART8_IRQHandler
    DCD     SPI4_IRQHandler
    DCD     SPI5_IRQHandler
    DCD     SPI6_IRQHandler
    DCD     SAI1_IRQHandler
    DCD     LTDC_IRQHandler
    DCD     LTDC_ER_IRQHandler
    DCD     DMA2D_IRQHandler
    __Vectors_End
    __Vectors_Size  EQU  __Vectors_End - __Vectors
                    AREA    |.text|, CODE, READONLY
    ; Reset handler
    ; Dummy Exception Handlers (infinite loops which can be modified)
    ;HERE ARE THE DEFAULT_HANDLERS -> DELETED BECOUSE I ONLY CAN POST 7000 Chars
                    B       .
                    ENDP
                    ALIGN
                     IF      :DEF:__MICROLIB
                     EXPORT  __initial_sp
                     EXPORT  __heap_base
                     EXPORT  __heap_limit
                     ELSE
                     IMPORT  __use_two_region_memory
                     EXPORT  __user_initial_stackheap
                     LDR     R0, =  Heap_Mem
                     LDR     R1, =(Stack_Mem + Stack_Size)
                     LDR     R2, = (Heap_Mem +  Heap_Size)
                     LDR     R3, = Stack_Mem
                     BX      LR
                     ALIGN
                     ENDIF
                     END
  • Heap_Size       EQU     0x00000200 ; this line will determine the size of the heap allocation
  • Hello Clive,
    i know its irritating - but can you explain how i should change this section?
    Thanks / The solution of your Link / google link i can not transfer for me.
    I'm not so familiar with the SDRAM and Scatterfile / Mappings ...
  • I just don't understand why it needs to be explained in such painful detail, may be if you're a student, or have no programming experience, perhaps you can provide some context. May be you need to experiment and think a bit, read associated documentation, and CS texts.
    So let's recap:
    The heap here is set for 512 bytes, as you've got 4MB or so, perhaps you can expand this to a much bigger number of bytes which you can allocate with malloc(), calloc(), etc. Dynamic memory in this context is helpful because it's large, the memory is slow, and it won't eat into the "size" the evaluation copies of Keil limit you too. You have to make decisions on how you best use the resources you have available, and there suitability to specific tasks.
    You can direct the HEAP, and specific static allocations into SDRAM using the earlier supplied scatter-file or equivalent. You probably want most static allocations into regular SRAM, along with the STACK, because it's materially faster the SDRAM in the cacheless Cortex-Mx family. Also if your statics have initializers that's going to eat into the FLASH load region which must copy out to SDRAM/SRAM at startup. That initialization is done in __main, before your main() is called, and after you've initialize the external memory and buses in SystemInit().
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
       .ANY (+RW +ZI)
      RW_IRAM2 0xD0000000 0x00400000  {  ; SDRAM (4M) the name is arbitrary
       startup_stm32f429_439xx.o (HEAP) ; Name of Object matching your startup_xxx.s name
       *(.sdram) ; All sections tagged as .sdram from All objects
    char buf[256] __attribute__ ((section(".sdram"))); // static allocation from SDRAM
    unsigned char *sdrambuf = malloc(1024 * 1024); // dynamic allocation from HEAP in SDRAM
  • Hello Clive,
    i did the following changes. I changed the value from the HEAP_SIZE to more or less 4MB. My Map-File looks now like the following, it's only a piece from it:
    //Buf is the Variable which should be located in SDRAM -> The Adress 0xd000... is correct
    buf                               0xd0000000   Data         256  system_stm32f4xx.o(.sdram)
    Execution Region RW_IRAM2 (Base: 0xd0000000, Size: 0x00400000, Max: 0x00400000, ABSOLUTE)
    0xd0000000   0x00000100   Data   RW         3019    .sdram              system_stm32f4xx.o
    0xd0000100   0x003fff00   Zero   RW            2    HEAP         startup_stm32f429_439xx.o
    Now Im trying to debug the Project step by step to try to understand the problems like you told me. Im started by the startup file and then i go through the SystemInit Function called in the Startup - File / everything works fine. In this function is the ExtMem_Ctl() called. When im debugging there step by step, the error occures in the following line:
    FMX_Bank5_6->SDCR[0] = 0x000029D0
    The Error which occures is: Cannot access target. Shutting down debug session.
  • The SDRAM works fine jet. Thanks for your support clive, but my mistake was a wrong define.
    One last question, how fast is the external SDRAM?
    Is there a big difference between the internal local Storage and the external SDRAM ?
  • Dear Clive,
    Can you give me the download link again?
    I follow the exactly the same as your suggestion in forum.
    But I still don't know how to create SystemInit_ExtMemCtl(); in STM32F769 Discovery board.
    Please send me the example project file.
    Thanks.
    Regards,
    Thiha Kyaw
