HY-LPC1788 GPIO Problem
Hello Dudes.a few month ago i bought one HY-LPC1788-CoreBoard (Gold Color!) And I started to using it in my project.Fortunately,I Could run the LCD,Touch & USART and THE RED LED on the LPC1788.But If i change the PORT and PIN it don't work.
for example when i choose the on board led (P2.21) its working good and after that when i change the port (for example change P2.21 to P3.21 OR P2.21 to P0.21) it is not working.
What is wrong with this LPC1788-CoreBoard !??
and this is my code....
0up.ir/do.php
Tanx.
  • "What is wrong with this LPC1788-CoreBoard !??"
    Probably nothing. It's almost always the owner who is to blame. Either by doing something wrong. Or by incorrectly assuming things.
    Sorry, I have zero interest in downloading any archive, extract and look at. This is an end-user forum. Not payed-for premium support.
    It's your task to figure out that the pin is free to use.
    And how to adjust the pin configurations to make the new pin work.
    And how to connect external hardware to probe if you got your program to correctly play with the new pin.
    Note that some boards have straps or other hardware that blocks some pins from use - or requires reconfiguration of the hardware.
  • Have you asked HAOYU Electronics ?
    Why would that be necessary? It's highly unlikely to be the board at fault.
    And it's obviously not the coder.
    More likely to be the alignment of the planets.
  • Like to try to help but am a little afraid to download the code.
  • P3[0] to P3[31] I/O Port 3: Port 3 is a 32-bit I/O port with individual direction controls for each
    bit. The operation of port 3 pins depends upon the pin function selected via
    the pin connect block. Pins 0 through 24, and 27 through 31 of this port are
    not available.
    P2[13] / EINT3 /
    I2STX_SDA
    50 - I/O P2[13] — General purpose digital input/output pin. 5 V tolerant pad with 5
    ns glitch filter providing digital I/O functions with TTL levels and hysteresis.
    I EINT3 — External interrupt 3 input.
    I/O I2STX_SDA — Transmit data. It is driven by the transmitter and read by
    the receiver. Corresponds to the signal SD in the I2S bus specification.
    I would say there are only about 14 P2 pins nothing greater than P2[13]
    and Onl a few P3 pins can be used looks like P3(25) may only be available.
    UM10360
    Chapter 7: LPC17xx Pin configuration
  • www.nxp.com/.../UM10470.pdf
    Sorry looking at the wrong user manual
    the P3.20s and P2.20s do exist after all.
  • on schematic where does pins 81 and 195 hook up to?
    that is from the data sheet for 208 pin chip
    www.nxp.com/.../LPC178X_7X.pdf
  • Hello again and thank you for your Help.
    yes i read the "UM10470" first .
    Pin 81 is P2.21 [on Board Red LED]
    pin 195 is p3.22
    this is my code ....
        int main(void)
        PINSEL_ConfigPin(0,21,0);
        PINSEL_ConfigPin(2,21,0); //on Board red LED
        PINSEL_ConfigPin(3,17,0);
        PINSEL_ConfigPin(3,21,0);
        PINSEL_ConfigPin(2,15,0);
        GPIO_SetDir ( 0 , (1<<21) , 1) ;
        GPIO_SetDir ( 2 , (1<<21) , 1) ; //on Board red LED
        GPIO_SetDir ( 3 , (1<<17) , 1) ;
        GPIO_SetDir ( 3 , (1<<21) , 1) ;
        GPIO_SetDir ( 2 , (1<<15) , 1) ;
        while(1)
        FIO_SetValue( 0 , (1<<21));
        FIO_SetValue( 2 , (1<<21)); //on Board red LED
        FIO_SetValue( 3 , (1<<17));
        FIO_SetValue( 3 , (1<<21));
        FIO_SetValue( 2 , (1<<15));
        Delay(0xfffff);
        FIO_ClearValue( 0 ,(1<< 21) ) ;
        FIO_ClearValue( 2 ,(1<< 21) ) ; //on Board red LED
        FIO_ClearValue( 3 ,(1<< 17) ) ;
        FIO_ClearValue( 3 ,(1<< 21) ) ;
        FIO_ClearValue( 2 ,(1<< 15) ) ;
        Delay(0xfffff);
    P2.15 Blinking
    P2.21 Blinking
    P0.21 Remain High without any change
    P3.17 Remain Low without any change
    P3.21 Remain High without any change
  • But you still haven't posted any indication that you have read the schematics and verified if there are external hardware connected to "problematic" pins.
    The photos of the board linked above - which you haven't confirmed is the correct board - shows headers for P1 and P2. But I don't see any headers for P0 or P3. Only by reading the schematics would you know if the board manufacturer intends you to be able to play with the pins you are having troubles with. I notified you about this in my first post - but all you have returned back with is defending the use of the pin that controls the red LED - a pin that you do not have problems with...
  • Dear per westermark,sorry and thank you for your attention. I'm using HY-LPC1788-CoreBoard Link www.hotmcu.com/hylpc1788core-p-40.html
    The photos of the board linked above - which you haven't confirmed is the correct board - shows headers for P1 and P2. But I don't see any headers for P0 or P3...
    I Think in the schematic The P1 and P2 are the name of the connectors and not the name of the ports
    if you want the reference please look at this document of LPC1788
    " elty.pl/.../HY-LPC1788-Core_SCH.pdf "
    and this is colorful pin out :) the LED1 [PTA34] is the P2.21 OnBoard LED
    developer.mbed.org/.../hy-lpc1788-core_pinout_for_mbed.png
    HY-LPC1788-Core_SCH.pdf this very useful document that i used for my project.
    i connected the SMD LED to my pins = p0.21 , p2.15 , p2.21 , p3.17 , p3.21
    and with this code just p2.15 and p2.21 (red LED on Board) work.
    in debug mode:
    there is no differ between the Pins but only p2.15 and p2.21 work.
    thank you very much for your time and attention :)
  • I didn't see anything colliding with P0.21.
    But P3.17 and P3.21 are data lines, and needed when interfacing with K4M563233G/K4M513233E. Are you really sure you should try to play with them as GPIO outputs, when they are in some situations driven by other chips? Exactly why did you select these pins to try to "blink"?
  • yes about the Port3 you right .
    according to the schematic the P3.17 and P3.21 connected to the K4M563233G But what about the P0.21 ?
    P0[21] — General purpose digital input/output pin see Page 92 at "UM10470".
    and Dude you can find P0.21 in "HY-LPC1788-Core_SCH.pdf" by searching P0.21.
  • looks like P0.21 is wired to pin 57 of P2 from your schematic. What test equipment are you using
    to see the signal on pin 57 of P2 connector. Maybe it is difficult to see the toggle using
    a Digital Voltage meter.
  • according to the code ... I Think because of similar function of P2.21 and P0.21, The blinking of the Pins can be seen by eyes and Voltmeter.
    I tested the code and only P2.15 and P2.21 blinking. :|
    * I increased the Delay time for sure.
