Hi I just want to make a TCP socket connection. I configure everything as the "Creating a Network Application" page tell.
as system start to debug or work it halts on netInitialize(). even the codes before this function doesn't work.
would you please help me on this ?
#include "rl_net.h" #include "GPIO_LPC17xx.h" int32_t tcp_sock; // TCP socket handle uint32_t tcp_cb_client (int32_t socket, netTCP_Event event, const NET_ADDR *addr, const uint8_t *buf, uint32_t len); void send_data (void); int main(void) { // Allocate and initialize the socket. GPIO_SetDir (2, 1, GPIO_DIR_OUTPUT); GPIO_PinWrite (2, 1, 0); // LED on: set port netInitialize (); GPIO_PinWrite (2, 1, 1); // LED on: set port // Allocate a free TCP socket. tcp_sock = netTCP_GetSocket (tcp_cb_client); while(1); } // Notify the user application about TCP socket events. uint32_t tcp_cb_client (int32_t socket, netTCP_Event event, const NET_ADDR *addr, const uint8_t *buf, uint32_t len) { switch (event) { case netTCP_EventConnect: // Connect request received break; case netTCP_EventEstablished: // Connection established break; case netTCP_EventClosed: // Connection was properly closed break; case netTCP_EventAborted: // Connection is for some reason aborted break; case netTCP_EventACK: // Previously sent data acknowledged break; case netTCP_EventData: // Data received break; } return (0); } // Connect to TCP server and send data. void send_data (void) { // IPv4 address: 192.168.0.1 NET_ADDR addr = { NET_ADDR_IP4, 2000, 192, 168, 0, 1 }; // IPv6 address: [fe80::1c30:6cff:fea2:455e] //NET_ADDR addr = { NET_ADDR_IP6, 2000, // 0xfe, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // 0x1c, 0x30, 0x6c, 0xff, 0xfe, 0xa2, 0x45, 0x5e }; if (tcp_sock > 0) { switch (netTCP_GetState (tcp_sock)) { case netTCP_StateUNUSED: case netTCP_StateCLOSED: // Connect to TCP socket server on port 2000 netTCP_Connect (tcp_sock, &addr, 0); break; case netTCP_StateESTABLISHED: // Connected, send the data if (netTCP_SendReady (tcp_sock) == true) { /* Example uint8_t *sendbuf; sendbuf = netTCP_GetBuffer (2); sendbuf[0] = 0x01; sendbuf[1] = 0x55; netTCP_Send (tcp_sock, sendbuf, 2); */ } break; default: break; } } }
