I am a programmer at (C8051f980 (slabs I would like to try Conditional Breakpoint I did not know where to write the command line, for example BS COUNT ==4
On an 8051 device, conditional breakpoints will only work with the uVision simulator. Maybe only expensive In-Circuit Emulators could do this. There are two ways to define such breakpoints: In the uVision debug command line: - Start the debugger. On the bottom of the uVision window, you should see the command window. http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_outputwin.htm
- In the breakpoint window you can define the breakpoint as well: http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_breakpnts.htm
