I recently completed an edx course using Keil 4.74 on the TM4C123GXL. I'm trying to base a new project on an exercise using a UART that I did for the class. In the course project files were already set up for us. I created a new project and copied the code files (.h, .c, and .o) into the new projects directory. I've gone through all the target options and set them the same as the original project. I keep getting the following error when I try to build it
"FCARM - Output Name not specified, please check 'Options for Target - Utilities'"
The original project builds without any errors. It doesn't have any output file or image files folder set. I don't understand what FCARM is. What file should I be referencing here.
If someone could recommend a good reference for creating a new project that would be also be a big help.
You might want to look for the keil example projects. You can compile those and compare against your own.
C:\Keil_v5\ARM\Boards\TI\DK-TM4C129x
Other board: C:\Keil_v5\ARM\Boards\TI\EK-TM4C1294XL
The other TI board is performing UART output. C:\Keil_TI\EK-TM4C1294XL\Blinky
This is your board, I think:
C:\Keil_v5\ARM\Boards\TI\EK-LM4F232
I'm using Keil_v4 since that was what was required for the class, so I'm at least basically familiar with it. I have Keil_v5 installed but the directory C:\\Keil_v5\ARM\Board doesn't exist on my computer. I have been able to build all of the projects you listed from the Kiel_v4 directory.
I wouldn't mind starting with one of these projects. Unfortunately they seem to use very different defines for referencing register than what I'm used to. We used GPIO_PORTA_DATA_R where it looks like this project uses GPIOA->DATA. Is it possible to use the other style of referencing ports so I don't have to go through and modify all the code I already have?
I would try the following:
Make a new uvision project and target the device you are working with. I found your part when I chose the Legacy Device Database. You may have to install the legacy device database if it is not installed. Then Add you Main file into the project along with all supporting files that the main file will require.
You may want to compare the working projects from Keil to the new project you are trying to make.
I would use Keils Start up . s file to start your project with. You can add any assembly code, h files. See what type of errors come up then search google to see if other people have encountered them.
Or maybe you can get the project you have to work. Take a look at this page:
http://www.keil.com/support/man/docs/uv4/uv4_ut_fcarmuv.htm
Look in Utilities to see why the project wants to use FCARM
Like you need to build a file-system type structure for bitmaps or html files?
Look very carefully about what you dragged into the project, and perhaps be more subjective.
Right click on all files in the Project Navigator and bring up File Options. Looks like you may have a file with option Image Compression checked marked.
"You may have to install the legacy device database if it is not installed."
How would I install it. I looked in the Pack Installer and couldn't find Legacy. Is this something I need to download separately?
The processor on the board is a TM4C123GH6PMI7. The project files I have that work list the device as TM4C1231C3PM, so that is what I have been using. On the Target tab the same project says LM4F120H5QR. I thought that was the old name for the Tiva Launchpad I'm using. Is that the legacy device I should be using?
You can find Legacy here: www2.keil.com/.../
Cortex M
If you also want to work with ARM7 ect then also ARM choice
I checked each file. Most of them have Image Compression checked but greyed out so the check-box is inactive, and can't be unchecked. There is one object file that I was told is part of the grader. It had Image Compression checked and I was able to uncheck it. I still got the same error. I'll try making a new project and not including that file next. I'll have to comment out all the references to it and see what happens.
We have a winner. Getting rid of the Grader object code allowed me to make a new project that worked.
Whether I have the correct project file setting is still in question. I got the legacy database installed. I still don't see a TM4C123GXL device. Would the best choice be to use the processor number, TM4123GH6PM, as the device. This device is available in both the Software Packs and the Legacy Database. Is there a reason to use the Legacy version?
I'll have to read more about FCARM to know why I would want to use it. For now it just looks like extra stuff to confuse me as I start using a new controller.
Westonsupermare Pier, Said; "Like you need to build a file-system type structure for bitmaps or html files?". At the moment I'm working on an interface controller to receive commands from a PC through one UART, and monitor and control 2 other pieces of equipment through there serial interfaces. There isn't a file system involved. In the online class I just took they included an object file for grading and were using an OS, called TExaS, that I believe was written by the instructors. That could have depended on a filesystem I'm not aware of. I did change the OS setting to none in the project I got working.
Gary, Thank you for being patience, and helping me work through this. I'll be waiting to hear if you think I guessed right on the device name, and whether to use the legacy or the current version.
Terry
I also did not see your board in the list. But I did see a board that had your device.
The EK-LM4F232\Blinky program is targetting the TMC4C123GH6PGE part. I think the board is likely the same as the TM4C123GXL Launch pad. You can look for differences try to change it if need be.
I think you may be able to get your old project working. If you find any file with options set to image_compression and then removing the check mark.
I guess I was just confused. Now it's time to make this thing talk.
Thanks again!
Thank you Gary Olson for that point about File Compression. That worked for me.
