Dear All
Keil: 5.17 Language: Assembler (and later C) "Use Memory Layout from target Dialog" is checked CPU: LPC1768 Target environment: The simulator Target set up: The default values created by the uVision Wizard, that is
Area Start Size IROM1 0x0 - 0x80000 Checked IRAM1 0x10000000 - 0x8000 Checked IRAM2 0x2007C000 - 0x8000 UnChecked
I do not have a "private" scatter file, the project is using the auto generated.
I am trying to write a ram check routine in assembler for the RAM and use it before I call the SystemInit and __main.
If I show various $$ linker values I get the following result.
LDR R0, =|Load$$RW_IRAM1$$Base| R0 = 0x00001DD4 LDR R1, =|Load$$RW_IRAM1$$Limit| R1 = 0x00001DDC LDR R2, =|Image$$RW_IRAM1$$Base| R2 = 0x10000000 LDR R3, =|Image$$RW_IRAM1$$Length| R3 = 0x00000008 LDR R4, =|Image$$RW_IRAM1$$Limit| R4 = 0x10000008 LDR R5, =|Image$$RW_IRAM1$$RO$$Base| R5 = 0x10000000 LDR R6, =|Image$$RW_IRAM1$$RO$$Length| R6 = 0x00000000 LDR R7, =|Image$$RW_IRAM1$$RO$$Limit| R7 = 0x10000000 LDR R8, =|Image$$RW_IRAM1$$RW$$Base| R8 = 0x10000000 LDR R9, =|Image$$RW_IRAM1$$RW$$Limit| R9 = 0x10000008 LDR R10, =|Image$$RW_IRAM1$$RW$$Length| R10 = 0x00000008 LDR R11, =|Image$$RW_IRAM1$$ZI$$Base| R11 = 0x10000008 LDR R12, =|Image$$RW_IRAM1$$ZI$$Limit| R12 = 0x10000298 LDR R13, =|Image$$RW_IRAM1$$ZI$$Length| R13 = 0x10000290
Question 1: Shall I use |Image$$RW_IRAM1$$RO$$Base| to determinate the start of the RAM ?
Question 2: How do I get the actual size/end of the RAM, as defined in the project ? It seems that no linker variable is either 0x00008000 or 0x10008000
Question 3: How can I compile/linker time determinate if the IRAM2 is checked? The following does not work
IF :DEF:|Image$$RW_IRAM2$$Base| IMPORT |Image$$RW_IRAM2$$Base| ENDIF IF :DEF:|Image$$RW_IRAM2$$Base| LDR R13,|Image$$RW_IRAM2$$Base| ENDIF
