Hi, I'm using Cortex-M4 TM4C129XNCZAD I noticed that in the technical support/configure startup code, you have the option to modify the PLL multiplier and the PLL divider values. My configuration wizard doesn't have this option. Should I add them manually and if yes, do you have an example code?
thanks. Khaled.
