Hi All, I am using uVision v2 for my project. Previously It was working fine but suddenly from a day when I launch the uVision V2 then It hangs and in task manager it display "SECsplashwnd in not responding". I am using windows & for this application. If any one have faced same problem and fixed it plz provide the solution.
Are you really using uVision2. That was released in 1998 - about 17 years ago!
I suggest you try an up-to-date version.
As Reinhard says, uVision-2 is really ancient!
"I am using windows &"
You mean Windows 7 ?
So that's 2 or 3 Windows generations later than what uVision-2 was designed for - I'd say you've had your money's worth by now?!
Anyhow, ISTR - from the distant past of last century - that this "splash screen hang" was not unknown on UV2.
What happens if you delete your project before starting uVision?
Look in the help files to see if there's a command-line option to start without the Splash screen ...
Yes I understand its very old. But due to some reason I cannot switch to newer version.
There are no command line in uVision V2. Any other way to resolve this issue?
"There are no command line in uVision V2"
I'm pretty sure there was!
"Any other way to resolve this issue?"
Have you tried the two suggestions I've already given?
"I'm pretty sure there was!"
Yes - there was!
Look in the GS51.pdf document ("Getting Started with uVision-2") - Chapter 12...
"Look in the GS51.pdf document ("Getting Started with uVision-2") - Chapter 12..."
I had checked command line option but same problem stuck at launching screen.
Yes I had tried both the solution provided by you.
Any other suggestion?
Hi Andrew,
Thanks, your first solution works for me . I deleted the project file and launch uV2 and it works.
