I wonder about icon of files in Project windows. Especially, what's different red colored three bars in the left and non bars of icon ?
Thanks.
It is described here: http://www.keil.com/support/man/docs/uv4/uv4_ca_filegrp_att.htm
Thanks for your reply.
But, I really mean that other image of files ICON. That is refer to URL : softwareji.tistory.com/169.
This Keil version is Keil5(V5.11.2.0).
You are not using the current version of the product, however there is also a documentation that comes with the product (and this contains a similar page that explains the old icons).
Use Help - uVision Help to open this documentation.
The icons have been changed lately. The icon with the 3 red dots on the left indicates: the item (in this case a file) has specific options settings.
Appreciated !!
Which is why it's important to state the version(s) of the tool(s) you're using in your posts!
Especially when they are old versions!
"however there is also a documentation that comes with the product (and this contains a similar page that explains the old icons)"
It is still available (though hidden?) online:
http://www.keil.com/support/man/docs/uv3/uv3_ca_filegrp_att.htm
See: http://www.keil.com/forum/59733/#msg193996
