elliptic curve cryptography on 8051
Hey guys, I am working on making Elliptic Curve Cryptography El-Gamal in 8051 MCU using Keil uvision 4. I want to make it 128 bit, so I need to use GMP library. However, to use GMP I usually download it in mingw-get-setup first, so I think it won't run if I just copy the gmp.h to my project in Keil.
My questions are :
1. how can I use gmp in 8051 using Keil?
2. Or should I compile it first in gcc, then just download the hex file to 8051? How to program the register in gcc?
Thanks for your attention :D
Best regards
0
