fcheck do not work(MDK 4.70 NAND)
I'm using mdk 4.70, i can use finit & fformat normally, but cannot use fcheck normally. I'm sure if some configurations are nor correct.(fcheck returns 1 in any circumstance)
  • driver:
    #include <File_Config.h>
    #include <string.h>
    #include <LPC24xx.h>
    #include "NAND_LPC24xx.h"
    //-------- <<< Use Configuration Wizard in Context Menu >>> -----------------
    // <o0>Chip select used for NAND <0x00=> CS0
    //                               <0x01=> CS1
    //                               <0x02=> CS2
    //                               <0x03=> CS3
    #define NAND0_HW_CS  0x01
    //------------- <<< end of configuration section >>> -----------------------
    /* EMC data bus */
    #define EMC_NAND_BASE  (0x80000000 + 0x1000000 * NAND0_HW_CS)
    #define EMC_ALE_ADDR    0x00080000
    #define EMC_CLE_ADDR    0x00040000//0x00100000  changed by wangyuan, 20140406
    #define EMC_DATA8 *((volatile U8 *)(EMC_NAND_BASE))
    #define EMC_ADDR8 *((volatile U8 *)(EMC_NAND_BASE + EMC_ALE_ADDR))
    #define EMC_CMD8  *((volatile U8 *)(EMC_NAND_BASE + EMC_CLE_ADDR))
    #define PIN_RB   (1<<6)//(1 << 12) changed by wangyuan, 20140406  /* MCB2400 */
     *      NAND driver prototypes
    static U32 Init         (NAND_DRV_CFG *cfg);
    static U32 UnInit       (NAND_DRV_CFG *cfg);
    static U32 PageRead     (U32 row, U8 *buf, NAND_DRV_CFG *cfg);
    static U32 PageWrite    (U32 row, U8 *buf, NAND_DRV_CFG *cfg);
    static U32 BlockErase   (U32 row, NAND_DRV_CFG *cfg);
      NAND Device Driver Control Block
    const NAND_DRV nand0_drv = {
      Init,
      UnInit,
      PageRead,
      PageWrite,
      BlockErase,
  • fcheck() function only works for drives which use Embedded File System.
    In the RL-ARM User's Guide for fcheck (http://www.keil.com/support/man/docs/rlarm/rlarm_fcheck.htm), this is not stated explicitly, but you can see that only EFS drives are allowed as input parameter and attempt to check the FAT media will result in error.
  • you mean we can only use fcheck("S:"), fcheck("R:"), fcheck("F:")
    but it's impossible to use fcheck("N0")?
  • Correct, fcheck() only works on drives which use Embedded File System.
