Anyone know how to access or install the Keil ARM Compiler Extensions 1.0.0 Software Pack which was announced in the Keil Information Update - March 2015? It doesn't seem to be available through the pack installer or uVision updates.
The 'Keil::ARM_Compiler' software pack is available on the keil.com webserver. Please be sure to press the green 'Check for Updates' button in the left upper corner of the 'Pack Installer'.
I appreciate the reply, but how about a specific link? I've searched the ARM web server and WWW in general with no success.
As I mentioned in my original post I tried the pack installer (including Check for Updates) which let me download the CMSIS 4.3.0 update. There is no option to download the Compiler software component.
To anyone else vexed by this issue, I finally found the Compile software component by invoking the Pack Installer and not selecting the target processor for my current project (as I normally do to select components germane to that target). By not selecting a target, I see the Keil:ARM_Compiler selection among the packs for all devices.
If you select a device on the right hand side in the Pack Installer, you preselect the packs that can be used for this device on the left hand side. I fully agree with you that the Compiler Pack should be listed in this case as well. I have forwarded this info to our engineering.
If you want to have a direct link to download the compiler pack, you can go to http://www.keil.com/dd2/pack/ and search for 'Keil ARM Compiler extensions' in your browser. When you expand this section, you see a 'Download' button. After downloading the *.pack file you can double click on it to start the Pack Installer or you can drag and drop it to the Pack Installer window.
