Fill unused sector in flash with random value
Hi Guys,
I have a LPC2292 system and i use a linker file to flash the FLASH / ROM on the board. The FLASH is totally 256KB divided into a number of sectors. My code is around 31KB and occupied the sectors 0,1,2,& 3 . Each of these sectors are 8KB each .
My requirement is that i pad the remaining 1KB space left in sector 3 with some default value.
ARMLINK: FILL UNUSED FLASH CONTENT WITH PREDEFINED VALUE : http://www.keil.com/support/docs/3407.htm
Seems to be the way to go about it . However END_OF_BLOCK (END_ADR - START_ADR) FIXED EMPTY 0x0 {} seems to substract the START_ADR from the END_ADR and i get an error;
Here is my linker file :
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x00000000 0x00040000  {    ; load region size_region
  ER_IROM1 0x00000000 0x00040000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_RAM1 0x80000000 0x00100000  {  ; RW data
   .ANY (+RW +ZI)
  RW_RAM2 0x81000000 UNINIT 0x00020000  {
   .ANY (+RW +ZI)
  RW_IRAM1 0x40000000 0x00004000  {
    Startup.o (+ZI +RW)
    RTX_Config.o ( +RW)
    checksum.o (+ZI +RW )
   .ANY (+RW +ZI)
 END_OF_BLOCK 0x00008000 - 0x00007EFC FIXED EMPTY 0x0 {}
Error :
.\Obj\TL100-V069.axf: Error: L6291E: Cannot assign Fixed Execution Region END_OF_BLOCK Load Address:0x00000104. Load Address must be greater than or equal to next available Load Address:0x00007fe8.
Is there something silly that I am doing here ? Is this the best way to pad my sector. In other words i want to ensure i use up all the sector 3.
  • No response in so many 5 days :(
  • I write a seperete utility to take hex file, pad unused area and calculate checksum over whole image.
  • You could try something like this...
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
       .ANY (+RW +ZI)
       .ANY (+RW +ZI)
        Startup.o (+ZI +RW)
        RTX_Config.o ( +RW)
       .ANY (+RW +ZI)
    LR_IROM2 +0 {
      ER_BLANK_REGION +0 FILL 0xFFFFFFFF 0x00007EFC {}
    You will probably need to adjust the fill size (0x00007EFC) to allow for the RW_IRAM1 compressed initialisation data to ensure all the ROM is completely filled. Its size will vary depending on the content.
    There may be a way to embed this calculation into the scatter file itself so the size is automatically adjusted for the actual RO code and RW initialisation data sections sizes, but I don't know it (yet).
    JT
