Hi experts, we wanna put a mask rom memory in our system, so I need to move parts of our code (API funcitons/const data) into this ROM as library, that is, the main application put at other RAM/ROM can call/access these funtions/data.
The challenge is this ROM image will be made once like One Time Programmable (OTP). So what I can think is in ROM it cannot invoke any external symbols outside except I play some tricks by using RAM. I name this as absolutely placed rom library.
My problem is that I move Func_A into ROM region (#pragram section XXX), but Func_A has dependency on a armlib funtion named __aeabi_ddiv. How do I move this library funtion into ROM? Do I need to create a new project? but if so, I don't need the _main symbol.
P.S. I use scatter file section selector to tell linker to put Func_A at ROM region.
Thanks a lot, Alex
I didn't think anyone did use mask-programmed chips anymore, unless maybe for extreme temperature ranges where flash retention isn't optimal.
