Retargeting: Return error from _sys_read()
Dear all,
The below implementation of _sys_read() returns an error code (a negative number, e.g. -7) if the underlaying file system functions indicates an error. The caller of _sys_read() (the C lib) seems not to accept such an error handling and repeatedly calls _sys_read() in order to complete the read operation. This ends up in an infinite loop.
How can I escape the "read loop" in the error case?
int _sys_read (FILEHANDLE fh, unsigned char * buf, unsigned len, int mode)
  int ret = EOF;
  struct __FILE * fp = (struct __FILE *)fh;
  if (fp != NULL)
    if (fp->handle == STDIN)
      /* Standard Input device. */
      while (len)
        *buf = ITM_ReceiveChar();
        len --;
        ++buf;
        if('\r' == *buf )
          break;
      ret = len;
#if _RETARGET_USE_FILESYSTEM
    else if (NULL != fp->fd)
# if (_RETARGET_USE_DATAFLASH_FILE && _RETARGET_USE_SD_CARD_FILE)
      if ((fp->handle == DATAFLASH) || (fp->handle == SD_CARD))             // both
# elif _RETARGET_USE_DATAFLASH_FILE
      if (fp->handle == DATAFLASH)                                          // only DATAFLASH
# elif _RETARGET_USE_SD_CARD_FILE
      if (fp->handle == SD_CARD)                                            // only SD_CARD
# endif
        I16 err;
        U32 size = FILESYSTEM_FRead(buf, 1, len, fp->fd);
        // It is in fact very simple if we support case (A):
        // - if not len bytes read, EOF was reached or an error occured
        // - if no error occured len bytes are read and the remaining bytes
        //   is 0, which corresponds FS_ERR_OK
        // -> we can thus return the result of FS_FError()
        err = FILESYSTEM_FError(fp->fd);
        if ((err == FS_ERR_OK) || (err == FS_ERR_EOF))
          ret = len - size;
        else
          ret = err;
#endif // _RETARGET_USE_FILESYSTEM
  return ret;
0
