about PIN configuration in LPC1768
I have started to program with lpc1768. In an example code in keil. I see that in this function it defines the pin P0.25 both GPIO and AD0.2, is it possible?
Also I cant figure out how does this code configure GPIO for P0.25 by '= ~(3<<18)'
 void ADC_init (void) {
  LPC_PINCON->PINSEL1 &= ~(3<<18);      /* P0.25 is GPIO                      */
  LPC_PINCON->PINSEL1 |=  (1<<18);      /* P0.25 is AD0.2                     */
  LPC_SC->PCONP       |=  (1<<12);      /* Enable power to ADC block          */
  LPC_ADC->ADCR        =  (1<< 2) |     /* select AD0.2 pin                   */
                          (4<< 8) |     /* ADC clock is 25MHz/5               */
                          (1<<21);      /* enable ADC                         */
  LPC_ADC->ADINTEN     =  (1<< 8);      /* global enable interrupt            */
  NVIC_EnableIRQ(ADC_IRQn);             /* enable ADC Interrupt               */
  • The pin can't be both. But the two assigns is there because the first assign uses &~ which can only clear flags. And the second assign uses | which can only set flags. And to get the value 01 from any previous value, you need both a clear and a set operation. Most sample code tends to assume that the registers have the default reset value which normally is 00 - and then no clear is needed. But a robust code should handle any combination of original bit values.
