Hello all. I have been looking at the ccu4_timer sample program and decided to upload it to my xmc4500 hexagon board. Now I am trying to output the ccu4 timer onto a gpio on the extension card that comes with this xmc4500 kit. The reason I want to output this timer to an external gpio pin is because I want to stick a logic analyzer probe on it and measure the period to see how often the interrupt is triggering. Is it operating at 1ms? 10ms? 100ms?...etc. I will be using pin 41 of the extension card.
My setup: http://imgur.com/0ue0MRt
Related MCU pin: http://imgur.com/p4mDG0o
The code in main.c of ccu4_timer:
/********************************************************************************************************************* * HEADER FILES ********************************************************************************************************************/ #include <xmc_ccu4.h> #include <xmc_scu.h> #include "stdio.h" #include "XMC4500.h" /********************************************************************************************************************* * MACROS ********************************************************************************************************************/ #define SLICE_PTR CCU42_CC43 #define MODULE_PTR CCU42 #define MODULE_NUMBER (2U) #define SLICE_NUMBER (3U) #define CAPCOM_MASK (SCU_GENERAL_CCUCON_GSC42_Msk) /**< Only CCU42 */ /********************************************************************************************************************* * GLOBAL DATA ********************************************************************************************************************/ XMC_CCU4_SLICE_COMPARE_CONFIG_t g_timer_object = { .timer_mode = XMC_CCU4_SLICE_TIMER_COUNT_MODE_EA, .monoshot = true, .shadow_xfer_clear = 0U, .dither_timer_period = 0U, .dither_duty_cycle = 0U, .prescaler_mode = XMC_CCU4_SLICE_PRESCALER_MODE_NORMAL, .mcm_enable = 0U, .prescaler_initval = 0U, .float_limit = 0U, .dither_limit = 0U, .passive_level = XMC_CCU4_SLICE_OUTPUT_PASSIVE_LEVEL_LOW, .timer_concatenation = 0U }; /* CCU Slice Capture Initialization Data */ XMC_CCU4_SLICE_CAPTURE_CONFIG_t g_capture_object = { .fifo_enable = false, .timer_clear_mode = XMC_CCU4_SLICE_TIMER_CLEAR_MODE_NEVER, .same_event = false, .ignore_full_flag = false, .prescaler_mode = XMC_CCU4_SLICE_PRESCALER_MODE_NORMAL, .prescaler_initval = 0, .float_limit = 0, .timer_concatenation = false }; /* Interrupt counters */ volatile uint32_t g_num_period_interrupts; volatile uint32_t g_num_compare_interrupts; volatile bool period_match; /********************************************************************************************************************* * MAIN APPLICATION ********************************************************************************************************************/ /* Interrupt handlers */ void CCU42_0_IRQHandler(void) { g_num_period_interrupts++; XMC_CCU4_SLICE_ClearEvent(SLICE_PTR, XMC_CCU4_SLICE_IRQ_ID_PERIOD_MATCH); period_match = true; } void CCU42_1_IRQHandler(void) { g_num_compare_interrupts++; XMC_SCU_SetCcuTriggerLow(CAPCOM_MASK); XMC_CCU4_SLICE_ClearEvent(SLICE_PTR, XMC_CCU4_SLICE_IRQ_ID_COMPARE_MATCH_UP); } int main(void) { /* Local variable which holds configuration of Event-1 */ XMC_CCU4_SLICE_EVENT_CONFIG_t config; config.duration = XMC_CCU4_SLICE_EVENT_FILTER_5_CYCLES; config.edge = XMC_CCU4_SLICE_EVENT_EDGE_SENSITIVITY_RISING_EDGE; config.level = XMC_CCU4_SLICE_EVENT_LEVEL_SENSITIVITY_ACTIVE_HIGH; /* Not needed */ config.mapped_input = XMC_CCU4_SLICE_INPUT_I; /* Ensure fCCU reaches CCU42 */ XMC_CCU4_SetModuleClock(MODULE_PTR, XMC_CCU4_CLOCK_SCU); XMC_CCU4_Init(MODULE_PTR, XMC_CCU4_SLICE_MCMS_ACTION_TRANSFER_PR_CR); /* Get the slice out of idle mode */ XMC_CCU4_EnableClock(MODULE_PTR, SLICE_NUMBER); /* Start the prescaler and restore clocks to slices */ XMC_CCU4_StartPrescaler(MODULE_PTR); /* Initialize the Slice */ XMC_CCU4_SLICE_CompareInit(SLICE_PTR, &g_timer_object); /* Enable compare match and period match events */ XMC_CCU4_SLICE_EnableEvent(SLICE_PTR, XMC_CCU4_SLICE_IRQ_ID_PERIOD_MATCH); XMC_CCU4_SLICE_EnableEvent(SLICE_PTR, XMC_CCU4_SLICE_IRQ_ID_COMPARE_MATCH_UP); /* Connect period match event to SR0 */ XMC_CCU4_SLICE_SetInterruptNode(SLICE_PTR, XMC_CCU4_SLICE_IRQ_ID_PERIOD_MATCH, XMC_CCU4_SLICE_SR_ID_0); /* Connect compare match event to SR1 */ XMC_CCU4_SLICE_SetInterruptNode(SLICE_PTR, XMC_CCU4_SLICE_IRQ_ID_COMPARE_MATCH_UP, XMC_CCU4_SLICE_SR_ID_1); /* Configure NVIC */ /* Set priority */ NVIC_SetPriority(CCU42_0_IRQn, 10U); NVIC_SetPriority(CCU42_1_IRQn, 10U); /* Enable IRQ */ NVIC_EnableIRQ(CCU42_0_IRQn); NVIC_EnableIRQ(CCU42_1_IRQn); /* Program a very large value into PR and CR */ XMC_CCU4_SLICE_SetTimerPeriodMatch(SLICE_PTR, 65500U); XMC_CCU4_SLICE_SetTimerCompareMatch(SLICE_PTR, 32000U); /* Enable shadow transfer */ XMC_CCU4_EnableShadowTransfer(MODULE_PTR, XMC_CCU4_SHADOW_TRANSFER_SLICE_3); /* Configure Event-1 and map it to Input-I */ XMC_CCU4_SLICE_ConfigureEvent(SLICE_PTR, XMC_CCU4_SLICE_EVENT_1, &config); /* Map Event-1 to Start function */ XMC_CCU4_SLICE_StartConfig(SLICE_PTR, XMC_CCU4_SLICE_EVENT_1, XMC_CCU4_SLICE_START_MODE_TIMER_START_CLEAR); /* Generate an external start trigger */ XMC_SCU_SetCcuTriggerHigh(CAPCOM_MASK); period_match = false; while(1U) { while(false == period_match); period_match = false; /* Generate an external start trigger */ XMC_SCU_SetCcuTriggerHigh(CAPCOM_MASK); } }
Any help is greatly appreciated.
