identifier is not defined
I am trying to use HAL driver for STM32L053C8 discovery board.
In DMA.h I defined:
typedef struct
  DMA_Channel_TypeDef    *Instance;          /*!< Register base address                  */
  DMA_InitTypeDef       Init;           /*!< DMA communication parameters           */
  __IO DMA_StateTypeDef  State;        /*!< DMA transfer state                     */
  void                  *Parent;           /*!< Parent object state                    */
  //void                  (* XferCpltCallback)( struct __DMA_HandleTypeDef * hdma);     /*!< DMA transfer complete callback         */
  //void                  (* XferHalfCpltCallback)( struct __DMA_HandleTypeDef * hdma); /*!< DMA Half transfer complete callback    */
  //void                  (* XferErrorCallback)( struct __DMA_HandleTypeDef * hdma);    /*!< DMA transfer error callback            */
}DMA_HandleTypeDef;
then in ADC.h I include that DMA.h file but after compilation, the compiler reports:
..\Inc\ADC.h(127): error: #20: identifier "DMA_HandleTypeDef" is undefined DMA_HandleTypeDef *DMA_Handle; /*!< Pointer DMA Handler */
..\Src\DMA.c: 0 warnings, 1 error
Actually there is no red cross on the right of DMA_HandleTypeDef in Keil uvision5 IDE in ADC.h file.
typedef struct __ADC_HandleTypeDef
  ADC_TypeDef                   *Instance;              /*!< Register base address */
  ADC_InitTypeDef               Init;                   /*!< ADC required parameters */
  __IO ADC_StateTypeDef                 State;                  /*!< ADC communication state */
  //__IO uint32_t                 ErrorCode;              /*!< ADC Error code */
}ADC_HandleTypeDef;
I dont know the reason why that happenes. Can anyone help me? Thank you.
