Bin file download at specific address in flash of microcontroller(LPC2148) using ulink2
I have ulink2, Keil uVision4 and My board with LPC2148 microcontroller.
I can download ulink2 .hex file and .axf file using ulink2.
But i want to add CRC in my binary, So I approached like this.
I used command line option In the dialog Project — Options for Target — User to get bin file from AXF file and written a program for CRC calculation and putting(appending) back that crc into that binary( this is CRC appended file). I invoked that program same In the dialog Project — Options for Target — User.
I have boot loader at 0x0000 to 0x1FFFF and after word application binary from 0x2000 to end of flash.
if i download CRC appended file using boot loader via USB. Its working fine. CRC check is also passing.
But i want to automate this thing So
Now i want to download this bin file using ulink2 to 0x20000 address.
I tried http://www.keil.com/support/man/docs/uv3/uv3_fl_hexdownload.htm
method by putting bin file instead of hex file, It is not working and also does not satisfy my requirement. Because I have to create separate project for this.
I am not able to download bin2hex convector from
http://www.keil.com/download/docs/113.asp
Is any other link exist?
