RTX-RTOS configuration issue on ADI ADuC7024
I am recently using uVision 5(with legacy device database[no RTE] installed) to test RTX-RTOS on my ADuC7024 MCU. However, the test project can compile correctly but it always gets stuck at the "os_sys_init" function during debugging. I suspect there is something wrong with my configuration files but I cannot find any clue. Can some expert help? Thanks in advance!
There are only 3 user files in this test project: ADuC702x.s, RTX_Config.c, and main.c. And I have already selected RTX Kernel in the Target Options window.
I got the startup file ADuC702x.s after I created this test project. The SWI_Handler function configuration portion is:
; Exception Vectors
;  Mapped to Address 0.
;  Absolute addressing mode must be used.
;  Dummy Handlers are implemented as infinite loops which can be modified.
Vectors         LDR     PC, Reset_Addr
                LDR     PC, Undef_Addr
                LDR     PC, SWI_Addr
                LDR     PC, PAbt_Addr
                LDR     PC, DAbt_Addr
                NOP                            ; Reserved Vector
                LDR     PC, IRQ_Addr
                LDR     PC, FIQ_Addr
                EXTERN Undef_Handler
                EXTERN SWI_Handler
                EXTERN PAbt_Handler
                EXTERN DAbt_Handler
                EXTERN IRQ_Handler
                EXTERN FIQ_Handler
Reset_Addr      DCD     Reset_Handler
Undef_Addr      DCD     Undef_Handler
SWI_Addr        DCD     SWI_Handler
PAbt_Addr       DCD     PAbt_Handler
DAbt_Addr       DCD     DAbt_Handler
                DCD     0                      ; Reserved Address
IRQ_Addr        DCD     IRQ_Handler
FIQ_Addr        DCD     FIQ_Handler
; Reset Handler
                EXPORT  Reset_Handler
Reset_Handler
; Setup PLL
                IF      PLL_SETUP <> 0
                LDR     R0, =MMR_BASE
                MOV     R1, #0x01
                STR     R1, [R0,#POWKEY1_OFFSET]
The RTX-Config.c file was re-named version of "C:\Keil_v5\ARM\RL\RTX\Config\RTX_Conf_ADuC702x.c". I just have to omit it here since it will make this message too long.
And the main.c file is very simple:
__task void test_task(void){
        uint32_t i = 0;
        while(1){
                i++;
                os_dly_wait(100);
int main(void){
        os_sys_init(test_task);
        while(1);
__irq void DAbt_Handler(){
        while(1);
__irq void FIQ_Handler(){
        while(1);
__irq void PAbt_Handler(){
        while(1);
__irq void Undef_Handler(){
        while(1);
